Geebax
Christian_Meyer Posted at 2018-6-7 17:57
My friend, I finally did the test that you said re install system in the control and actualize it and the problem persisted, because I took it to the DJI store to review warranty.
The issue is not able to be seen in your first clip, but it is certain present in the second clip, and it most certainly is jello effect. But it seems to happen when the aircraft is on thje ground, so that suggests that the gimbal is out of adjustment. This can happen if the sensistivity of the gimbal servo system is not set correctly. Unfortunately, it requires that you send it back to DJI to fix.
At the same time, there looks like there is another, seperate issue with the gimbal moving to one side and back again, this is also going to require you to send it in for repair.
