Problem - Overall Status ABNORMAL
11442 15 2018-6-2
Maraš
Flight distance : 160115 ft
Montenegro
Hi, i got problem after sistem update, aircraft status shows message ABNORMAL on Overall status, and after that ! Calibrating the Vision Sensors with DJI Assistant on a PC or MAc is recommended. Anyone knows what to do? Thanks
2018-6-2
void68
Flight distance : 469685 ft
As long as the drone behaves normally during test flights (esp. vision sensors acting like they should) I wouldn't do anything. I got the same problem after doing a vision sensor recalibration for fun. It stopped at 80% calibration each time, with different computers and monitor sizes, all DJI told me was "use original cables" what I did and "send it to us for check" which I dont want. However still the drone flies normally and the vision sensors in fact do sense what they should. DJI doesnt want to debug their software but leave it to the customers. Internet is full of ppl with drone's ABNORMAL overall status.
2018-6-2
Jenee 2
Flight distance : 7852129 ft
Are you saying that the problem occurred after a firmware update?
Can you turn on the RC and drone and tell us what firmware is installed in the RC and drone. Open the GO 4 app and go to the General tab and About at the bottom to show firmware versions.
2018-6-2
Jeff Millard
Flight distance : 503635 ft
I recently updated a P4P+ R/C and then got the message to Calibrate the Vision system. I linked the aircraft to a standard controller to see if the issue was caused by the update. The message was still there. So I simply ran the vision system calibration using DJI Assistant 2 connected to the aircraft. I did this on a MacBook Air, so a large screen is not required. It took about ten minutes to run the calibration, then another ten to update. It did fail the first time and got hung up at around 80%, so I rebooted everything and ran it again. The second time it completed and I haven't had the error message since.
Jeff
2018-6-3
Maraš
Montenegro
Jenee 2 Posted at 2018-6-2 22:54
Yes, after firmware update.
2018-6-3
DJI Diana
Flight distance : 2408 ft
Hi, I'm sorry to hear about the issue that you are experiencing. Please restart the drone and try to refresh the firmware again to check if it fixes or not, if still no good luck, please show us a screenshot of the error message, thanks!
2018-6-3
Maraš
Montenegro
Jeff Millard Posted at 2018-6-3 03:29
Jeff
Thanks Jeff, I did the same and now is everything OK!
2018-6-4
Maraš
Montenegro
DJI Diana Posted at 2018-6-3 20:40
Hi Diana, problem is solved thanks to Jeff. Thanks anyway.
2018-6-4
Jeff Millard
Maraš Posted at 2018-6-4 07:48
That's great news! I'm glad you're back in business. Fly safely and have fun!
Jeff
2018-6-4
DJI Diana
Maraš Posted at 2018-6-4 07:49
Hi, thank you so much for your update, glad to know that you have solved the problem, happy flying.
2018-6-5
djiuser_Nzi1oTbGmIdZ
Sir overall status abnormal.when I calibrate IMU it failed with error 13,firmware-aircraft-v02.200.0700 and rc-v1.9.3.0 (phantom4)
2018-7-13
When I start p4 aircraft this massage appear
2018-7-13
Dot
Botswana
PLIZ HELP DJI PHANTOM 3 STANDARD MOTORS WONT START, I RECEIVE THIS MESSAGES
2018-10-4
ALABAMA
Flight distance : 10442687 ft
Move to a different area and see if it helps.  You must be in an area where there is steel close by.
2018-10-4
djiuser_FkWXxlmG4Igk
Saudi Arabia
2019-2-5
davidgalyon
djiuser_Nzi1oTbGmIdZ Posted at 2018-7-13 08:08
Did you ever get this fixed? I'm having the same problem, doesn't seem to matter how many times i RESTORE DEFAULTS or UPDATE FIRMWARE, I get the same IMU CAL failure. (error -50)
Can you Help?
2019-8-3
