ProRes RAW Corrupt Files - URGENT
Mr Ludo
Flight distance : 1822831 ft
Hello,
I've updated my Inspire 2 with the Zenmuse X7 the other day to the latest firmware. I recorded footage to the SSD drive on the drone and it all worked totally fine and I can playback the files in all the editing softwares (Adobe Premiere Pro, After Effects, Quicktime Player.....).
I then put a second SSD memory card (which I formatted) in the I2 Drone and recorded a second lot of footage later the same day. When I went to copy all the files to an external hard-drive after the shoot, all the files from the 2nd SSD card are corrupted and can not be read by any editing software or video players. Any help would be most welcome on how to recover these files as soon as possible. I'm using a Mac.
Quicktime player says
"QuickTime Player can't open "A015_C019_20180724_PR00000.mov".
Adobe Premiere Pro says:
"File Import Fail"
Adobe After Effects says:
"After Effects error. Source files has no importable streams. Please check that it is a valid video/audio file ( 86 :: 1 )
This is important I get his fixed fast as I'm with a very large client who is getting very tricky now.
Many thanks for any help,
Ludo
2018-7-26
jwilson2598
Flight distance : 600256 ft
I thought ProRes RAW was only Final Cut Pro X right now?
2018-7-26
Mr Ludo
Hi All and Jwilson2598,
After much research, yes you're correct, it is only Final Cut Pro X that does ProRes RAW PLUS Also Apple Motion can play and Render (and export the files in different codex's). Cost of £49 if you need it!
Hopefully Adobe will catch up soon.
2018-7-26
bachir_photo_ph
Flight distance : 20013228 ft
United Arab Emirates
Mr Ludo Posted at 2018-7-26 08:57
Hi Ludo,
I did a very bi shooting for a client , and i am having the same problems as yours , even final cut pro doesn't open... what did you do ?
2019-1-29
Mr Ludo
Jamaica
Hi,
My problem was that I just didn't have the plugin to play ProRes RAW. I'm not sure whether Adobe Premiere Pro now has the plugin for it. My fix at the time was to use Apple Motion to convert the files to ProRes 4444.
Hope that helps.
Ludo
2019-1-29
