Update Firmware "unsynchronized" and Home Point?
1555 12 2015-5-26
tdhines81
Flight distance : 988406 ft
When I update firmware, I get this:
========== 2014.01.01 00:00:10 unsynchronized ======
Packet: WM610_FW_V01.02.01.06.bin
Upgrading ...
Result: Success.
What does "unsynchronized" mean.  Also, I still am unable to set "bird home point" and "rc location."  Once I arm the bird, I then can set "bird home point," but still cannot set "rc location."  Still getting weak signal.  Bird is getting 15 sattilites.
Using IPad Air 2 ios 8.2
2015-5-26
Flight 1
Mines exactly the same. I haven't updated to new firmware yet. Mine was working OK till the last update
so was hoping this new one would sort it out. Obviously it hasn't.
2015-5-26
RichJ53
Flight distance : 1837356 ft
DJI can correct me if I am wrong. But it means that you are currently unsynchronized with the latest firmware. After you complete the update you will be synchronized. look at the log file:
[00010288]========== 2014.01.01 00:00:10 unsynchronized ======
[00010306]Packet [C:\WM610_FW_V01.02.01.06.bin] detected.
[00010316]Packet upgrade start...
[00010330]Packet checking...
[00010335]Done.
[00010340]Version checking[1]...
[00010345][01 00] v1.8.2729 -> v1.8.2729
[00010353][01 01] v1.8.2729 -> v1.8.2729
[00010382][03 05] v34.1.0.5 -> v34.1.0.5
[00010422][03 06] v2.0.5.14 -> v2.0.5.14
[00010433][04 00] v1.16.0.76 -> v1.16.0.76
[00010463][05 00] v2.5.6.1 -> v2.5.6.1
[00010479][08 00] v1.12.0.21 -> v1.12.0.21
[00010492][09 00] v1.7.0.3 -> v1.7.0.3
[00010543][11 00] v3.7.0.0 -> v3.7.1.0 need upgrade.
[00010603][12 00] v1.3.0.60 -> v1.3.0.60
[00010662][12 01] v1.3.0.60 -> v1.3.0.60
[00010724][12 02] v1.3.0.60 -> v1.3.0.60
[00010782][12 03] v1.3.0.60 -> v1.3.0.60
[00010837][15 00] v1.1.2.0 -> v1.1.2.0
[00010862][17 00] v1.1.0.1 -> v1.1.0.1
[00010922][17 01] v2.0.0.1 -> v2.0.0.1
[00010938][19 00] v1.0.8.96 -> v1.0.8.96
[00010943]Done.
[00012947]Waiting for user confirm...
[00022952]Timeout, start upgrade automatically.
[00022962]Firmware upgrading[1]...
[00022978][11 00] Firmware upgrading start...
[00103932][11 00] Firmware upgrade finished successfully.
[00103938]Done.
[00103944]Version checking[2]...
[00103948][01 00] v1.8.2729 -> v1.8.2729
[00103954][01 01] v1.8.2729 -> v1.8.2729
[00103994][03 05] v34.1.0.5 -> v34.1.0.5
[00104033][03 06] v2.0.5.14 -> v2.0.5.14
[00104044][04 00] v1.16.0.76 -> v1.16.0.76
[00104094][05 00] v2.5.6.1 -> v2.5.6.1
[00104104][08 00] v1.12.0.21 -> v1.12.0.21
[00104129][09 00] v1.7.0.3 -> v1.7.0.3
[00104173][11 00] v3.7.1.0 -> v3.7.1.0
[00104238][12 00] v1.3.0.60 -> v1.3.0.60
[00104313][12 01] v1.3.0.60 -> v1.3.0.60
[00104373][12 02] v1.3.0.60 -> v1.3.0.60
[00104433][12 03] v1.3.0.60 -> v1.3.0.60
[00104495][15 00] v1.1.2.0 -> v1.1.2.0
[00104513][17 00] v1.1.0.1 -> v1.1.0.1
[00104573][17 01] v2.0.0.1 -> v2.0.0.1
[00104603][19 00] v1.0.8.96 -> v1.0.8.96
[00104613]Packet upgrade finish successfully.
Rich
2015-5-26
tdhines81
RichJ53 Posted at 2015-5-27 08:57
DJI can correct me if I am wrong. But it means that you are currently unsynchronized with the latest ...
My log file only said what I mentioned in the first post.  Any thoughts?  No mention of "packet upgrade"
2015-5-26
RichJ53
tdhines81 Posted at 2015-5-27 09:15
My log file only said what I mentioned in the first post.  Any thoughts?  No mention of "packet upg ...
You are only looking at the result file that is located on the SD card root (WM610_FW_RESULT_AB) . There are two hidden folders that are on the SD card, you need to enable hidden folders under Windows folder options, then they will appear (greyed out). Click on the LOG folder and find this file name: WM610_FW_LOG_AB. Hope this helps you out.
Rich
2015-5-26
tdhines81
RichJ53 Posted at 2015-5-27 09:27
You are only looking at the result file that is located on the SD card root (WM610_FW_RESULT_AB) . ...
Thanks for your time.  Found log file:
[00010464]========== 2015.05.26 18:02:37 =====================
[00010542]Packet [C:\WM610_FW_V01.02.01.06.bin] detected.
[00010620]Packet upgrade start...
[00010741]Packet checking...
[00010789]Done.
[00010827]Version checking[1]...
[00010836][01 00] v1.8.2729 -> v1.8.2729
[00010845][01 01] v1.8.2729 -> v1.8.2729
[00010886][03 05] v34.1.0.5 -> v34.1.0.5
[00010925][03 06] v2.0.5.14 -> v2.0.5.14
[00010938][04 00] v1.16.0.76 -> v1.16.0.76
[00010964][05 00] v2.5.6.1 -> v2.5.6.1
[00010986][08 00] v1.12.0.21 -> v1.12.0.21
[00011005][09 00] v1.7.0.3 -> v1.7.0.3
[00011045][11 00] v3.7.1.0 -> v3.7.1.0
[00011105][12 00] v1.3.0.60 -> v1.3.0.60
[00011165][12 01] v1.3.0.60 -> v1.3.0.60
[00011225][12 02] v1.3.0.60 -> v1.3.0.60
[00011286][12 03] v1.3.0.60 -> v1.3.0.60
[00011355][15 00] v1.1.2.0 -> v1.1.2.0
[00011391][17 00] v1.1.0.1 -> v1.1.0.1
[00011465][17 01] v2.0.0.1 -> v2.0.0.1
[00011485][19 00] v1.0.8.96 -> v1.0.8.96
[00011494]Packet upgrade cancelled at version checking.
Again, any help would be appreciated.
2015-5-26
RichJ53
tdhines81 Posted at 2015-5-27 09:43
[00010464]========== 2015.05.26 18:02:37 ================= ...
At this point, maybe try another SD card and make sure you complete a fresh format to FAT32 or exFAT before putting the firmware file on the chip.
That's sometimes the root cause for update failures.
hope you can figure this out!
Rich
2015-5-26
RichJ53
2015-5-26
RichJ53
td,
After thinking about this and looking at my log... all of your update numbers are the same as mine. I believe this is why it says upgrade cancelled.... there is nothing to update
2015-5-26
tdhines81
Flight 1 Posted at 2015-5-27 08:21
Mines exactly the same. I haven't updated to new firmware yet. Mine was working OK till the last upd ...
Flight 1. Did you ever get your bird to set bird location or rc home point location?  Also have notice the video connection does not seem to be as good?  Spent a fortune for this bird and firmware updates seem to be all over the place.  I was just fine until this last firmware update!
2015-5-29
Flight 1
tdhines81 Posted at 2015-5-30 10:02
Flight 1. Did you ever get your bird to set bird location or rc home point location?  Also have no ...
I have updated to the latest firmware. At the same time I deleted the app from iPad Air and reinstalled it (on advice from another thread) and now RTH is working. This seems to have worked for me.
2015-5-29
tdhines81
Flight 1 Posted at 2015-5-30 10:30
I have updated to the latest firmware. At the same time I deleted the app from iPad Air and reinst ...
Thanks a bunch.  Will give that a try right now.  Have wait until the rain stops.  Thanks again!
2015-5-30
tdhines81
2015-5-30
