4 deletw
1199 31 2018-8-28
Levskyy
Words 4 deletw
2018-8-28
Jakab Gipsz
Hungary
Install the DJ assistant 2, plug in Spark and do a factory default reset, or do firmware flash.
Or:
Put that firmware back that working earlier.
And more endurance, because if you're in doubt then you're stupid, calm ...
2018-8-28
Levskyy
Words 4 delete
2018-8-28
Datree
Flight distance : 21371 ft
i had the same problem turns out you gotta disable beginner mode.
2018-8-28
Levskyy
Of course im not in beginner mode
2018-8-28
Datree
before you turn anything on switch sports mode to the off position. now turn on your RC and AC and connect your phone. on the phone make sure you are in Normal mode and take off once in the air switch over to sports mode and see if that works.
2018-8-28
Levskyy
Of course i tried that also, i tried many many things
2018-8-28
drewhoover
Flight distance : 323455 ft
To enable sport mode, you just have to flip the switch in the middle of the controller. Have you not done this?
2018-8-28
Levskyy
Words 4 deletw
2018-8-29
Jakab Gipsz
Hungary
And you trying Assistant 2 in developer mode, seeng what modevthe drone?
2018-8-29
Levskyy
Words4 delete
2018-8-29
Jakab Gipsz
Hungary
Levskyy Posted at 2018-8-29 00:50
Yes im tried dev mode, but dont know what u mean with modevthe drone?
connect the remote control and look at the operating mode in the dashboard or basic settings. the default button in the lower right corner, reset the remote control settings.
2018-8-29
Levskyy
Word4 dwlwte
2018-8-29
Jakab Gipsz
Hungary
You try reflash the RC firmware only?
2018-8-29
Levskyy
Words 4 delete
2018-8-29
Greg - TheHuski
Flight distance : 944308 ft
Possible Faulty RC???...
2018-8-29
Jakab Gipsz
Hungary
Levskyy Posted at 2018-8-29 01:50
Nope, yesterday i downgraded to oldest firmware RC & Spark, tried to use sport mode & int flight modes and everything was same, like in videos.
Today i upgraded RC & spark to newest and done that things in dev mode. Still can't access sport mode and, int flight modes only appear when it turned off... very weird :/
You certainly did not try it all yet. Logically, if Spark and Remote Commander firmware are flashing again, then they are all in factory state if there is no hardware failure then hardware failure. Intelligent mode and Sport mode also need a GPS signal that you probably can not see ... Or the Sport switch is defective. You can see the switchover and the current mode (P, A, S) in assistant 2, when switching, the letter will be dark in any mode.
2018-8-29
Levskyy
Words 4 delete
2018-8-29
Jakab Gipsz
Hungary
The new firmware has ruined the remote control for more people. This should not have ...
2018-8-29
Jakab Gipsz
Hungary
Levskyy Posted at 2018-8-29 01:57
I don't thing so. In litchi when S mode is turned off it says P-Mode, but when im turn on sports mode it says Unknown. That mean the sports mode button work. I almost 100% sure there is problem with intelligent flight modes switch and its software problem. But its only what i think :/
Make a screen photo of what Assistant 2 shows when you switch the remote control to Sport and return to normal. Did you quit the default?
2018-8-29
Levskyy
Words4delete
2018-8-29
Levskyy
Words 4 dwlete
2018-8-29
Jakab Gipsz
Hungary
I almost forgot: delete the Go 4 apps and the Litchi app and file manager with their libraries and then install a proven stable version of Go, for example. a 4.1.15. (for me this is flawless)
2018-8-29
Levskyy
Jakab Gipsz Posted at 2018-8-29 02:27
Done, with deleting litchi and DJI folders. Nothing much changed. IFM disabled but i can use it
IMF Enabled, i cant use it.
Cant use sport mode in any IFM mode.
Can't access IFM modes when connected with wifi, only can access when on OTG.
2018-8-29
AC5FF
Flight distance : 65194 ft
Quick Question.  In your video above you are showing some settings.  At the 15sec mark you show a P A F  switch.
I don't have access to my Spark at the moment to check, but I don't ever recall seeing this setting.   Did I miss something?
2018-8-29
Levskyy
Poland
That PAF switch its not switch. Only intelligent flight modes is switch. If you are not seeing it, install .15 app dji go app version, turn on spark, turn on RC, wait till connect, and after that connect your phone using OTG cable. Option will appear
2018-8-29
Jakab Gipsz
Hungary
Levskyy Posted at 2018-8-29 06:29
Sent PM.
RC reset you trying?  Power button and (maybe) FN button hold 9 sec.
2018-8-29
Levskyy
Done, nothing changed. Wifi > IFM not appear OTG > When enabled no icon, when disabled icon appear.
2018-8-29
wallin
Flight distance : 10886 ft
Czechia
Hi Levskyy, did you solve this issue? I have the same problem with my controller. When i turn switch into "S" mode, notting happens...
2018-9-5
Levskyy
Nope, cant fix it
2018-9-8
S-e-ven
Flight distance : 5922034 ft
Multiple flight modes switched.on?
https://forum.dji.com/forum.php? ... p;page=1#pid1389777
2018-9-8
wallin
I dont see multiple fl.modes into menu...
2018-9-12
