Horizon not level
4985 25 2018-9-16
Reclaimer106
Flight distance : 427382 ft
See attached video.
Imagine strafing/moving a drone to the left without a gimball, the horizon on right side of screen would be lower than horizon on left side if screen. By using a gimball, the camera should be leveld when the aircraft is not level.
In this video you can see the MA move to the left, but the horizon is not level. The right side of the screen is even higher than the left side. The gimball seems to over compensate?
When moving to the right, the opposite happens. When standing still the horizon seems to be level.
Gimball is calibrated on flat surface. IMU is calibrated on the same flat surface. After calibrating when I put the drone on a flat surface, the horizon is level.
Gimball is in follow, not FPV.
Do other MA pilots experience this too? What could be the cause of it?
Thanks alot for thinking with me!
2018-9-16
DJKOR
Flight distance : 2035676 ft
Are you flying in Sports mode? I've never gotten that unless I'm specifically in that mode.
2018-9-16
FI. Stanley
Flight distance : 148556 ft
Just contact dji support. Look like there is faulty with the gimbal.
2018-9-16
Reclaimer106
DJKOR Posted at 2018-9-16 12:15
Nope, not in sport mode
2018-9-16
DJKOR
Sorry. Early morning. Disregard my response. I was not looking at the angle right. It's opposite what you'd expect in sports mode. I'd definitely be opening a case with DJI
2018-9-16
Wachtberger
Flight distance : 261509 ft
Could it be that your gimbal setting is "FPV" and not "Follow"?
2018-9-16
Reclaimer106
It's in follow. Checked multiple times.
2018-9-16
hallmark007
Flight distance : 10017858 ft
Reclaimer106 Posted at 2018-9-16 13:49
MavAir has probably the best straightest gimbal of all dji drones, I suspect something is unhinged here.
2018-9-16
GDL
Flight distance : 2768694 ft
The camera may tilt when suddenly move to sideway. Don't know what cause this problem. But it will level again later when move smooth on side way. To avoid this problem you should not move suddenly to sideway. Always move slow and smooth for best stable video.
2018-9-16
Punchbuggy
Flight distance : 483166 ft
GDL Posted at 2018-9-16 17:57
Agree. And I've noted that it's particularly bad keeping a level horizon when slipping sideways in heavy wind. It could be that the gimbal doesn't know what "level" is if the little guy is already flying at an angle to compensate for the wind or a sudden sharp blast.
As you say, it should find level if you hover and perhaps do a slow 360 on the spot (the old trick with the P4s).
2018-9-16
Reclaimer106
It wasn't windy the day I made this video. I'm curious how this movement would look like on another MA, it's been like this since the start so i don't know any better. I showed interest in this problem just recently when people commented on another video of mine that the camera doesnt seem level. Could any1 make a sideways movement with a MA with a clear horizon in view? I'm really curious if it's the same or if it's just my drone with a faulty gimball.
2018-9-16
saviour
Flight distance : 604203 ft
Don't let others tell you that this issue is due to high wind or something.
I do such moves everytime I fly. The camera is always aligned to the horison when I fly sidewards, EXCEPT for when I accelerate, do a sudden move, do a sudden brake or fly in sport mode.
In your video, the gimbal is constantly missaligned which looks like it doesn't get stabilized at all. Open a case and send the drone in for warranty.
2018-9-16
DJKOR
The reason the speed is restricted in P-Mode is because of this exact reason. In P-Mode, you should be able to apply full stick forward/backward/left/right and the image will remain stabilised. P-Mode is made to reduce the maximum pitch and roll so that it does not exceed the pitch and roll limits of the gimble.
2018-9-16
A CW
Flight distance : 14103563 ft
I would return under warranty
2018-9-16
Punchbuggy
Hi again. Just checked video again (the replay was not good on low bandwidth when I tried to watch earlier). Now I can watch it fully, I have to agree - the gimbal should be working much better that that. I'd return it under warranty or DOA.
2018-9-16
Zatx
Flight distance : 158166 ft
I shot this in P-Mode and once maximum acceleration was reached my speed was constant. Definitely experiencing gimbal issues and it's not warrantied related, too many complaints of this type.
2018-9-17
saviour
I'm pretty sure you are in an illegal range to that plane..
2018-9-17
Reclaimer106
Zatx Posted at 2018-9-17 04:59
https://www.youtube.com/watch?v=368i9qq6hMU&t=2s
Yeh that horizon looks alot more level/smooth than mine Affraid it's gonna be a costly repair, but still worth it I guess
2018-9-17
Zatx
saviour Posted at 2018-9-17 05:02
Close, but not quite.
I was 1.5 miles from the airport. I notified the tower traffic controller before taking off and he was visually watching my drone during this shot and the C-130 pilot knew my precise location (which is one reason he turned towards me).
2018-9-17
Reclaimer106
Anybody knows how much a gimball replace/repair would cost by DJI?
2018-9-17
Atlas_Aus
Thailand
Howdy,
I have just started to use my MA fully and noticed a slight tilt in my footage, but not as bad as yours. Mind you I was doing a house shoot so the balance looks terrible.. I have done a gimbal balance but may have to redo ? Will keep watching this thread for developments.
2018-9-17
HedgeTrimmer
Your poor MA looks like it is flying Half in the Bag.
2018-9-17
A CW
Rolling the drone will often cause slight horizon tilt issues - good footage though
2018-9-17
Reclaimer106
Replacing 4 props also didnt work, rly trying anything here but affraid I will have to miss the drone for a while when sending it for repairs.
2018-9-17
bikelike
Any updates about result of repair? Warranty, costs? I am in the same situation.
2019-11-9
djiuser_9X40F7vMSsko
I just bought a dji inspire 2 and is doing this. Is a second hand with very low flights on. But is doing the same thing I see in your video. Did they find a fix?
2020-10-2
