Home point changed after disconnection.
1236 10 2018-9-23
fans681ac1c1
Flight distance : 550548 ft
My Samsung S7 disconnected while the M2Z was 1140m from the home point.
I restarted the S7 and resumed the flight. The M2Z was hovering (although it is set to RTH if disconnected!)
Looking at the summary of the flight on airdata, I see that the home point has been reset to the place where it disconnected.
Has anyone ever had such an experience? Is there an explanation?
2018-9-23
Packer Backer
Flight distance : 240948 ft
Not I but I am now following this thread
2018-9-23
Cool0102
2018-9-23
msinger
Flight distance : 228255 ft
Please upload your TXT flight logs here and post the links back here.
2018-9-23
Cool0102
Here are the flight logs:
1st part of the flight
2nd part
2018-9-23
msinger
Both of your logs show the home point is at 43.51875801, 5.50440745.
I'm not sure why Airdata is showing something different. It looks like a bug in their log viewer.
2018-9-23
Cool0102
Many thanks for your help...
This is what I understood seeing the logs...
I'll inform Airdata: as you say it should be a bug in their system
2018-9-23
Cool0102
Apparently, Airdata team worked on this problem.:
"Thanks for sharing those and reporting this - this issue should be now fixed.
Please let us know if you still see an issue there."
2018-10-8
Squashpile
Flight distance : 214019 ft
I have.. If the app crashes it will just hover and reset home point where it is hovering when you restart DJI app.
2018-10-10
Cool0102
I’m not sure... as only m’y Samsung was disconnected. So the home point didn’t change as Airdata has confirmed.
2018-10-10
scolagiaco
Flight distance : 452864 ft
Mine did something similar with the disconnections. It also kept asking for the same remote controller firmware update over and over again even though it said that the update was successfully completed. A couple times, it also said that there was a mismatch in the firmware. that got me thinking that you cant use 1 app for all the drones. I have the spark, the 1st Mavic and now the Mavic pro 2. I wonder if there is an issue with that?  error keeps calling itself "Remote connection link error"
2018-10-13
