What Is Your Max Wind Speed Limit?
20169 34 2018-10-7
DNR 1
Flight distance : 1689478 ft
I was just curious at what wind speed most pilots consider it unsafe to fly? I believe DJI states it at 22 miles per hour and a high wind speed warning will go off at 15 miles per hour. Normally, I'd say 12 mph is iffy and for me, 15 is probably the ultimate max. I was flying near a mountain ridge the other day and got a high wind warning, and wrapped it up pretty quickly. But it just had me wondering where most pilots draw the line. My informal rule is if it is windy enough to blow your car door shut, absolutely not! When I'm filming for others, I tell them that if it is too windy, cannot do it.
2018-10-7
Labroides
Flight distance : 9991457 ft
There is no simple max wind speed.
You have to consider the direction of the wind and how that may affect your return home as well as how far you need to fly.
If I can find a sheltered spot for launching, I've flown in winds up to 22 knots (25 mph) as long as the return flight will not be against a headwind.
If you aren't flying any great distance, the Phantom can easily hold position in winds of this strength and more.
2018-10-7
BeastMaster_101
Flight distance : 1082992 ft
Ive got the P3P and it handles anything up to 30-35 km/h without any issues of low RTH speed or any video jitter. Higher than that I get jitters in the video but the drone is perfectly fine.
2018-10-7
Bashy
Flight distance : 2354357 ft
If its gusting more than 30mph at 10m i normally stay home, but i have done some wind turbine flying and i bet it was gusting at around 40mph, i was in sports mode but the P4P was holding its own thats for sure.
Something you have to bear in mind though, if you fly in winds stronger than the ac's max wind resistance, your warranty (if applicable) may become invalid
2018-10-7
RedHotPoker
Flight distance : 165105 ft
People often experience flyaways, but no one ever mentions their drone being blown away...
I presume, these are overlapping experiences.
RedHotPoker
2018-10-7
Bashy
Some flyaways on here have been caused by too windy conditions for the drone, i think a few P3's have done gone walkabout cause the RTH speed was slower than the windspeeds
2018-10-8
DarkZero
Flight distance : 923127 ft
I have tested my P4A in 55kmh @ 15m AGL and it sat there like a champ. I then went up to 50m and did a bit of flying around. Then RTH and packed up and went home.
2018-10-8
solentlife
Flight distance : 1087530 ft
United Arab Emirates
Having lost my P3S into the river for flying out too far and headwind increased for run home - I am more careful now.
I look out window ... if I see tree movement that is above that of a breeze - I only consider low / close in sheltered work. Even that has caught me out but luckily no mishaps. Classic one of my recent 'garage workshop' update videos. Took off and all fine till I got round other side of the building and then my P3P was visibly fighting gusting winds.
I have to say that no matter what model I am flying ... unless its slope soaring glider - I do not enjoy flying in significant wind.
Nigel
2018-10-8
Bashy
solentlife Posted at 2018-10-8 04:23
Wind certainly removes some of the fun factor for me too, it goes from being fun to anxiety/stress pretty quick.
2018-10-8
Alvaro L
Flight distance : 8832 ft
20 km/h for operations between 50/75 metres height, measured and log registered with anemometer at ground level. This means a theorical 30 km/h at 50 metres height and 35 km/h at 75 metres heigh, as advised by spanish regulators and by DJI operational limits. I do it for security and since I mostly do photogrammetry work, high camera shaking is not good for results.
2018-10-10
Mark The Droner
Flight distance : 2917 ft
There have been lots of threads on this over the years.
My personal limits for an out and back run re winds at 400':  20 mph initial head wind, 15 mph initial tail wind, 10 mph cross wind.
2018-10-10
VetteGuyZ06
Flight distance : 429114 ft
If the tops of the nearby trees (app. 90 ft tall) are significantly moving, I don't fly.  I get wind warnings almost every flight, even though the wind is not blowing anywhere near 22 mph.
2018-10-17
Anthony8858
Flight distance : 9711 ft
Seems like basically the rule is "Don't fly on windy days".
Ok on breezy days.
2018-10-17
Mark Weiss
It's always blowing at least 30MPH here on the mountain where I live and I have managed to fly pretty smoothly, although crosswinds sometimes make the AC tilt beyond the range of the gimbal's abiliity to correct.
2018-10-24
DarkZero
VetteGuyZ06 Posted at 2018-10-17 11:05
I get wind warnings flying too fast some days, it's a bit touchy to be honest.
2019-1-29
embayweather
Flight distance : 556667 ft
Slightly aside from this post, most folk look at wind speeds at around 10m. How many of us check out winds higher than that before each flight? I run my own weather station and very often winds for higher levels are so much different to my readings. I would also suggest that flying in wind speeds of different levels require different skill sets.
2019-1-30
Bashy
I do think about winds at height somewhat but not as much as the 10m winds, reason being is that i can always bring it down to lesser winds if theres any issues, my max is about 30mph gusts at 10m, i know thats going to be at least 40mph gusts at 400ft, the only time i would fly in that scenario would be for a speed test or wind turbine shots...
2019-1-30
DonSteitz
I hit 30 mph gusts sometimes and my unit, a Mavic 2 Zoom handles it.
2019-7-19
bob37
Flight distance : 260384 ft
I use 15 mph, being half the max speed.  Gotta get home!
2019-7-19
Mark The Droner
I think the main reason DJI doesn't like high wind has as much to do with the gusty nature of a high wind rather than the speed.  It's a very rough ride out there with the sustained winds approaching 20 mph, and the roughness due to gusts is mostly hidden from the pilot due to the gimbal.  Try it with a P2V or an FC40 and you'd see how rough it is.
2019-7-20
JPilotR
Flight distance : 584662 ft
Depends on the mission, but generally 12-15 knots is my limit just because the quality will start to diminish after that, especially when trying to stitch a map together. At least, that has been my experience when I tried mapping in a sustained 15 knot wind on the ground, meaning at altitude the winds were markedly higher.
2019-7-20
Mark Weiss
The Northeast US had a very windy spring and early summer. I've not recalled a longer period of non-stop wind in many decades. One day in early June, the wind was strong enough to blow the hat off my head and I chose that opportunity to practice flying ATTI. The wind speeds were about 30 MPH continuous from the northwest with gusts to 40.
The craft flew fine. Granted, flying cross wind, the craft would tilt often pas the gimbal's ability to correct, plus progress was slow flying INTO the wind.On another day, not quite as windy, I was flying in P mode and tooling along about 13MPH when I got a motor overspeed warning. So I backed off the throttle a little more. Normal flight otherwise.
2019-7-20
Bashy
Mark The Droner Posted at 7-20 03:05
I would say their dislike of winds, ie limit of 22mph for p4p is purely because of the RTH speed, that speed has probably been worked out for best mileage per battery.
2019-7-20
Geebax
Bashy Posted at 7-20 18:52
My scientific method of working out wind speed works for me out in the countryside. I take a pee, and if the stream is horizontal, I don't fly.
2019-7-20
embayweather
I dislike high winds, simply because the higher the wind, either average or gust, the less the flying is enjoyable. In high winds you are constantly fighting to make sure the aircraft is on track, even with computer assistance. I use the trees where I fly to gauge wind speed on the ground and further up, and use that to determine if I am over my limit.
2019-7-21
Bashy
Geebax Posted at 7-20 19:08
ha, that works for me too lol
2019-7-21
David Martin Graff
Flight distance : 106566408 ft
We don't get lots of wind here in the southwest, but I'm from New York and if I adopted my principles since living here I'd likely fly unexpectedly far less given how many days of sunny but windy weather would preclude me from flying my Mavic Pro...
2019-7-21
Bashy
embayweather Posted at 7-21 04:20
I agree, for me >30mph gusts takes the fun factor out of it, i wont fly my anny (at 10m) shows higher than 30mph gusts before leaving home, bit of  lie i spose, cause its actually lower than that, anything above 25 gusts and i wont leave home, unless i have a specific reason, say wind turbines for example...
2019-7-21
Sean-newbie
Flight distance : 15997 ft
What procedure do people use for landing in windy conditiions?
Where I have concerns about it flipping I have started to catch it rather than land it.
2019-7-22
Bashy
Norway
I too hand catch where needed
2019-7-22
Bipolar2
Flight distance : 5007 ft
I was wondering this about this same issue because I was going to catch some storm damage today but the winds are at 18 mph.  I am going to check and see what they will be at the city I am going to.
2021-3-31
Mark The Droner
Bipolar2 Posted at 3-31 12:19
You should use a site such as uavforecast.com or windy.com and check the winds at the height you plan to fly.   Weather.com is not the place to check for wind.  Good luck.
2021-4-1
Bipolar2
Mark The Droner Posted at 4-1 03:48
Thank you very much.  Will do.
2021-4-16
djiuser_KTt3tZxMRtOj
Flight distance : 216827 ft
Argentina
Mark The Droner Posted at 2021-4-1 03:48
Thanks for the wind.com  Its amazing the amount of info they give you for free. Wow
2023-9-22
Shawgod
Flight distance : 5173104 ft
When I fly, I have flown in winds as high as 30 Mph but I feel as though I was pushing it.  I use the app UAV to get wind at different altitudes.  This is real important, as wind usually different, even though it doesn't look like it.  I also use an anemometer to measure the wind at ground level to make the decision as well.  I don't like to take chances with any of my drones.  I will never fly my Mini 2 at 30 Mph.  I would fly my Phantom 4 Pro and my Air2S, they can handle it.  But I wouldn't fly them too high.
2023-9-24
