cleber.frigo
Flight distance : 764180 ft
Brazil
I bought my 2 phantom vision plus yesterday, v3, and everything was working, unless the IOC, when I called the computer, called the IOC and the update took the drone system, the same thing happened to one user, Bryan was reported in another topic .
- Everything upgraded in recent versions.
- Gimbal not start or does not detect, as it was not connected.
- The camera works normally.
- The phantom usually works.
The very strange thing is that after about 10 minutes off the gimbal will work again, but if I turn off and turn on the phantom sometimes fails to rebind the gimbal and turn to the stake 0.
- May be heating problem in the gimbal system, after 20 minutes with the drone off, and called the gimbal worked after I restarted and ran 7x normal when I left a while on and rebooted, did not work again.
Could it be that the problem is just the upgrade, and we should expect a new update of the DJI?
