gimbal twitches
973 8 2018-12-24
Denissio
Flight distance : 242129 ft
Russia
hi all,
gave dron to the friend for couple of days, after return we have this twitches in some fly scenarios:
[backcolor=rgba(0, 0, 0, 0.8)]
can somebody explaine, what is wrong here? )
2018-12-24
theothernt
Flight distance : 436171 ft
If it continues to happen, it looks like a gimbal fault which may need replacement or repair
2018-12-24
DJI Natalia
Hi Denissio. We are very sorry for the trouble caused. Can you please try to calibrate the gimbal of your drone? If the issue persist, I suggest you refresh the firmware of your drone via DJI Assistant 2. Thanks.
2018-12-24
Lonesome Crow
Flight distance : 408606 ft
Did you loan your friend the same mobile device you normally use?  I would say yeah, you need to redo the DJI Go App and firmware on the bird if you did not loan him your mobile device.  Something is not matching correctly here.
2018-12-24
Denissio
Russia
DJI Natalia Posted at 12-24 12:53
Hi Denissio. We are very sorry for the trouble caused. Can you please try to calibrate the gimbal of your drone? If the issue persist, I suggest you refresh the firmware of your drone via DJI Assistant 2. Please keep us posted for further help. Thanks.
Hi Natalia,
thank you, I'll try today and will post here results.
2018-12-25
dronie1965
Flight distance : 24971795 ft
Were you in sportsmode? Looks like tou flew very fast and did a sudden brake, it looks like that was to heavy for the gimbal
2018-12-25
Denissio
Russia
dronie1965 Posted at 12-25 11:49
no, was flying in normal mode, twitches happened several times.
2018-12-26
DJI Paladin
Flight distance : 318 ft
Hi Denissio, it is advisable to calibrate first the IMU and then calibrate the gimbal. For your convenience, you may download DJI Assistant 2 using this link: https://www.dji.com/mavic/downloads and follow the video tutorials below on how to properly calibrate the IMU and how to update the firmware. Please keep us posted if the issue persists. Thanks for your support.
IMU calibration:
Restore factory:
Firmware Update:
2018-12-26
GroTToFlyeR
Flight distance : 1148937 ft
Denissio Posted at 2018-12-26 01:15
What phone are you flying with. Maybe he flew with a more updated phone. Or he crash maybe, hopefully not
2019-1-5
