Arct1C0n
I AM IN NO WAY RESPONSIBLE FOR ANY DAMAGE TO YOUR PHANTOM AS A RESULT OF TRYING MY TESTING OF "FREEZING" THE PHANTOM 3 IN THE REFRIDERATOR, YOU HAVE BEEN WARNED!!!
Ok, with that out of the way, i'll get to it. My very first P3 Pro has the gawd awful "crooked" horizon issues, no matter how many times I did the IMU calibration and gimbal alightment. Thinking it was hopefully a manufacturing flaw, I exchange it for a new one at local dealership. I was PISSED that my SECOND P3 Pro STILL had horizon issues!!!
I had read in forums that people have had luck basically "Freezing" their phantoms in the fridge to make the IMU chilled and then do a calibration under lower tempratures which apparently makes the IMU calibration more "accurate"
Outa desperation I did the following:
1. Removed LIPO battery *Lipos DO NOT like cold temps!*
2. Stuck in refridgerator with temprature of around 35 F
3. Left P3 Pro in fridge for about 30 minutes
4. Took out of fridge and set on VERY FLAT, EVEN and STABLE surface, my concrete bolted mantle in my case
5. Immedately fired up P3 Pro and went into advanced IMU calibration. It took longer then before due to temprature change.
6. After IMU was complete, I then did a Gimbal alightment test
The result? My horizon issue went completely away!!! I verified through the camera feed and using a bubble measure but that made my camera horizon issue go away!
I've done 3 flights so far and the horizon has been staying perfectly alighned since I did this. Your mileage could greatly vary but it DOES work!
Not my image but you get idea.
