JJB*
Flight distance : 12477300 ft
Hi,
Had a look at your flight.
First you started this flight with zero satellites and no reception.
OPTI mode after take-off, this for few seconds, into ATTI mode.
In OPTI/ATTI mode max height is limited, see warning "Max Altitude Approached. Wait for the GPS satellite signal recovery before ascend." This warning 4x in the GoApp.
After 46 seconds 4 satellites with no reception.
Still trying to fly higher (stick up) but nope, still at 30 meters.
At 1m6 seconds 10 sats and 2 bars, so latLon postions are there!
HomePoint recorded at 1m9 seconds and again at 1m30s.
At 2m57 a compass errror followed by speed and yaw errors (typical spark...)
At 3m26 Exit P-GPS and into ATTI mode. Away from home 290 meters.
In ATTI mode you have to control the AC by yourself, use the compass indicator to yaw back home and pitch forward. (in the log you only pushed up...)
Spark drifted on the wind in the heading 037 with some 8 m/s.
Distance away 290 meters, at the end distance of 606 meters.
After loosing connection with the RC and in ATTI Sparl will perform an autolanding.
My calulated guess is the orange marking on the map.
cheers
JJB |
