peted
![](https://forum44.djicdn.com/data/attachment/common/d3/common_10_usergroup_icon.png) lvl.1
Flight distance : 26411 ft
DJI Paladin Posted at 3-22 15:48
Hi Peted, my apologies for the trouble. May I know what happened prior to the issue? I would suggest you turn off your aircraft before launching the application and please do not touch both sticks until you hit OK then proceed with the RC calibration to see if the app will respond. Open the APP, go to general settings by tapping on 3 dots on the top left side- Tap on the remote controller settings and then calibrate the remote controller. If the issue persists, you can back up your files and then reinstall the app. You can also use a different mobile device so that we can isolate the issue. Thanks for your support.
I have tried every way possible, the controller is faulty.
I am also not able to connect up to Assistant 2 on my PC with version 2.07.... 2.06 had been working fine but now the USB virtual port is in the list but the software does not connect.
