sysop
Flight distance : 183084 ft
Slovenia
Hi, I had an accident with my Mavic Air. I took off, waited to lock GPS signal and made sure everything is as it should be. Only after that I slowly flew to the right and then it happened. Drone started to fly backwards on his own, I tried to correct the position so I slowly touched forward command. Drone moved a little forward and then again full speed backward. I push max forward but drone still went backward against the wall. It did not respond to my command. Optical sensors was ON, but didn't stop him. I don't know why. This should not happen. So it crashed into the wall. It didn't broke anything, because only felt 2 meters, but when I try to take off, it only lifts 20 cm and lands again. I am sure, there was some bug or something. Drone is still under warranty. What is the next step? Thank you.
Logs: https://www.phantomhelp.com/LogViewer/E251AVDN9DZR9LXEUAM5/#
If you need any other information, let me know.
