The Phantom 2
Flight distance : 22890 ft
Sweden
Ive noticed after my first recording with my newly bought used P2 that the video recordings has grayish horizontal lines running through the picture at all times, also one horizontal line in blue / purple color is appearing on the right side of the screen about 3 cm from the edge, this vertical line is only appearing every now and then and stays for a few seconds at a time.
I´m using a gopro 3 White and a 500 mW video TX located on the outside underneath the drone, i also have an IOSD mini at the same place as the video TX.
I didnt noticed the lines on the FPV monitor, maybe i just didnt saw them, but at least the horizontal line im pretty sure wasnt there in the monitor.
Could it be that my Video TX antenna was located beside the gopro camera only about 3 cm from the camera? I hadn´t had anymore chances to fly in a while due to heavy winds.
Some ideas to whats causing the problem would really be appriciated. Thanks.
