3rd party antenna options?
2057 11 2015-6-8
mackie1604
I saw some guys doing different antenna's for the controller to increase range.  Is there anything out there yet?
2015-6-8
salota8550 This user has been deleted
2015-6-8
gregg1r
salota8550 Posted at 2015-6-9 05:45
You can check this out:
http://fpvlr.com/store/product/phantom-3-advanced-antenna-kit/
I hope for the selling price that they work as advertised. $314, strange price for the lit and another $199 if you have them do the install.
I'm sure that there are some high gain antenna's available for less.
2015-6-8
DaGunn
Flight distance : 203117 ft
This should also boost signal.
http://lifehacker.com/5839243/us ... as-a-wi-fi-extender
2015-6-8
aburkefl
Flight distance : 78612 ft
The verbage specifically says this can be done on the Phantom 3, then the detailed instructions they provide show them working on an Inspire.
What's the possibility all the wires end up in the same places?
2015-6-8
jimcloud74
Flight distance : 1298317 ft
Fpvlr cording and antenna works. I just modded mine. It's a nice setup.
2015-6-8
mackie1604
jimcloud74@yaho Posted at 2015-6-9 10:15
How hard is it?  Can you show instructions?
2015-6-9
jimcloud74
mackie1604 Posted at 2015-6-10 00:21
Step by step. Very easy. Just be careful with the flat cables as to not disconnect them. If you do it isn't the end of the world, just lift the black tabs on the plug, plug cable back in, and push the tab back down. On a side note, I ran the cables up the middle and not up the right side. I did not want to cut any of the white glue that was holding the ribbon cables as I was afraid I would damage them. The cables were routed up the center with no issues.
http://fpvlr.com/guide/Installat ... %20Kit_20150421.pdf
It is for an Inspire remote but it is EXACTLY the same. I flew out 2.5 miles today and around with no signal loss with the basic antenna. No boost at all. Hope this helps.
2015-6-9
mackie1604
jimcloud74@yaho Posted at 2015-6-10 10:34
Step by step. Very easy. Just be careful with the flat cables as to not disconnct them. If you do i ...
When you say "Basic Antenna with no Boost" what do you mean?
2015-6-9
jimcloud74
mackie1604 Posted at 2015-6-10 11:46
No extra battery or wifi boosters. Just the internal connectors and the 9dbi antenna that mounts to the 3d printed bracket. It is costly at $179 but works and works well.
2015-6-9
mackie1604
jimcloud74@yaho Posted at 2015-6-10 11:56
No extra battery or wifi boosters. Just the internal connectors and the 9dbi antenna that mounts t ...
Looks like they have this kit for the P3 now http://fpvlr.com/store/product/phantom-3-basic-antenna-kit/
$174
2015-6-10
jimcloud74
mackie1604 Posted at 2015-6-10 22:56
Looks like they have this kit for the P3 now http://fpvlr.com/store/product/phantom-3-basic-antenn ...
Yes. That is where I got mine.
2015-6-10
