DISPV
Flight distance : 55207 ft
Hello all. First entry on 2022-10-20. USA Virginia.
In GO 4 app for Phantom 4 Pro v2.0 and iPad mini (older model). I would imagine that this would work for different iPad models. The easiest way I found to clear the caches:
1) Have your iPad Mini and Controller hooked up / plugged in, on, and talking with each other.
2) At the "Home Page" (for me it's a picture of the Phantom 4, the name at top left, a "hamburger" (three lines stacked) at top right, GO FLY banner at bottom right, and the Connected icon at bottom left. Below that is a menu bar with, from L. to R., Equipment, Editor, Skypixel, Me. The attributes may vary upon your model.
3) Tap on Me in the menu bar.
4) At the top of the window I see my DJI - given name with other information with a background image.
5) At the top right is a Settings Wheel just below my iPad power levels. Tap the wheel.
6) This is the Settings window. You now should see a line entry for Clear Cache. Tap that line.
7) You are now able to clear all types of cache on the iPad.
That's it. Good luck. Nick. |
