Gain setting after upgrading to ESC v2 and MOTOR 2312.
4018 12 2014-11-15
drone7
Flight distance : 51998 ft
Has anybody upgraded your old version of  ESC and MOTOR on PV2+ to the new ESC v2 and Motor 2312? The reason I'm asking is because I just bought the upgrade parts but have not installed them. I'm not sure if after the installation the GAIN must be adjusted being they are stronger motor, different ESC and props are slightly wider and stiffer. If so what is the right GAIN setting? and would the PT2 asistant program automatically recognize the changes? If I don't change the setting I'm afraid it might fly unstable and crash. I would appreciate some feedback. Thanks
2014-11-15
whyley27
this guy has installed the new upgrades to his phantom. dont know if he has messed with the gains, no harm in asking?
some good informative vids from there..
2014-11-15
uhayat
Flight distance : 191421 ft
Pakistan
2014-11-16 08:48
Hi, I haven't done this upgrade but I did get the Version 2 Phantom today which has the upgraded ESC's/Motors/Props.
While I was in the assistant changing my bird to Naza mode I noticed that the factory gain settings on the new Phantom are the same as the default settings applied by the assistant to both the Version 1 Phantom 2 and the version 2 Phantom 2 and it also flew very nicely with the same old version default gains.
2014-11-15
drone7
whyley27@sky.co Posted at 2014-11-16 08:47
this guy has installed the new upgrades to his phantom. dont know if he has messed with the gains, n ...
whyley27 - Thanks for the link that was very helpful in prepping my installation. The only thing I am worried about is the soldering part.  I only  have a little experience on this matter I guess I have to watch soldering 101 first. I guess GAIN doesn't have to be adjusted since it was not even mentioned on the video. I will just leave it as is.
2014-11-15
drone7
uhayat -  Thanks, you are right I will just leave it as is don't really wanna mess  with it. Do you know what is the best soldering iron to use (wattage wise)?.
2014-11-15
whyley27
a soldering iron between 30-45 watts you can use..
2014-11-16
drone7
whyley27@sky.co Posted at 2014-11-16 17:20
whyley27 - Thanks for the tip. I will look for at least 45W just to make sure.
2014-11-16
whyley27
no probs, good luck out there
2014-11-16
uhayat
Pakistan
drone7 Posted at 2014-11-16 10:57
uhayat -  Thanks, you are right I will just leave it as is don't really wanna mess  with it. Do yo ...
You're welcome, yes a 45 watt iron will work, however others advice a slightly higher wattage for the joints which connect to the ESC, the motor joints are slightly smaller. Also, you might want to fit the motors to the ESC's before they are fitted to the Phantom, outside, that will give you more room to solder them.
2014-11-16
drone7
uhayat@hotmail. Posted at 2014-11-17 06:46
You're welcome, yes a 45 watt iron will work, however others advice a slightly higher wattage for  ...
uhayat - Great advise, I was actually  thinking of that soldering the motor to ESC first before installing it to the body and soldering the ESC to the board.  This upgrade becomes more expensive than I thought. Now I have to buy a good soldering iron, lead, desoldering pump, Flux , desoldering wick and Brass Solder Tip Cleaning Wire. A good $70 more. My budget for this is already at the bottom of the pit. Lol
2014-11-16
Upnaway
drone7 Posted at 2014-11-17 08:12
uhayat - Great advise, I was actually  thinking of that soldering the motor to ESC first before in ...
A little help with soldering basic. Bruce Simpson of "RC Model Review" has an excellent video on Soldering techniques for RC planes.  One point that he makes is that a temperature controlled unit is best.
Link:
2014-11-16
uhayat
Pakistan
Upnaway Posted at 2014-11-17 13:21
A little help with soldering basic. Bruce Simpson of "RC Model Review" has an excellent video on S ...
Excellent video, thanks.
2014-11-17
drone7
Thanks for the advice guys I appreciate it.
2014-11-17
