Battery error
670 4 2019-12-25
RobinLim
Flight distance : 300466 ft
Singapore
for DJI Mavic pro
The controller shows battery error, the MP cannot take off.  Then connect the Drone with the controller; with controller plug to the Mac Book, turn on the assistance 2 apps.  After connecting to the Mac Book, the battery error disappeared.
What could be the casue of the error?
2019-12-25
lannes
Flight distance : 4465 ft
Battery firmware mismatch, I'd use the DJI Assistant 2 to refresh the AC firmware with the problem battery in the AC, make sure it's fully charged though.
2019-12-25
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching out to DJI Forum. As lannes at post #2 suggested please do a firmware refresh with the battery connected to the drone to isolate the said issue. Please keep us posted further assistance. Thank you.
2019-12-26
RobinLim
Singapore
Hi
Decided not to waste time and replace the spoiled battery.  The battery is not so reliable; which is suppose to have a high quality.  Charge the battery less than 15 times before it give way.
Charging method base on recommendation by DJI
2020-11-9
RobinLim
Singapore
Hi
Do anyone knows about the airmap flight status installed in Garmin fenix 5x?
unable to update the data  on the surrounding flight info.  " there is a error response code 400
thanks
2020-11-9
