mavic mini
839 3 2020-1-7
fansce81b7e5
Flight distance : 202566 ft
need a little help Please i live in a blue zone only 2 blocks from being out of it and im looking to buy a mavic mini but im not sure if i can fly becasue im in that blue zone .. so can someone tell me if i buy one will it fly because of this. also i have a iphone 6 plus will it work also???  thanks
2020-1-7
AY521
@fansce81b7e5 if you have your MM you will want to make sure you download the latest firmware and app.  When I originally received my MM the feature to unlock in blue zone was not available on the app.  With the updates from 12/31/2019, I can fly my MM in my backyard which is located in a Blue zone.  In addition I am using an iPhone 6s Plus.  If you can download the app to your iPhone 6 plus then you should be good to go.  I hope this helps.
2020-1-7
InspektorGadjet
Flight distance : 439915 ft
iPhone 6, 6s and 6 plus all work with no issues.
2020-1-8
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching out to DJI Forum. With regards to this inquiry as AY521 advised at post 2, please make sure to update the firmware of your DJI Mavic Mini and install the latest version of the DJI Fly application so that you can use the unlock feature pm your drone in a blue zone. Please make sure to follow local rules and regulation. Thank you for choosing DJI and safe flying
2020-1-8
