Every BLIMMIN time Dji release a firmware there is an issue!!!!
613 7 2020-4-28
TroutboyNZ
Flight distance : 1726486 ft
New Zealand
Got this today with new props on the Mavic Mini in perfect flying conditions, so add me to the list! There is ALWAYS something!!! It's as if... you know... they never really test the firmware before being released! Not good enough Dji!!!
Grrrr!!!!!!
Grrrr!!!!!!
2020-4-28
DAFlys
What happened when you replaced the propellor?
2020-4-28
Deucalion
Flight distance : 103091 ft
DAFlys Posted at 4-28 02:16
"What happened when you replaced the propellor?"
Lol
2020-4-28
Ice_2k
Flight distance : 1132575 ft
Romania
did you do what the error message asks you to do? The rear propellers are the reason for the uncommanded descends we've been seeing with the Mini.
2020-4-28
m80116
Flight distance : 3264131 ft
Actually very much more probably you didn't check your propellers before flying!
That error usually supervenes for rear upper motor rpm reached, actually meaning the props aren't producing enough lift.
You could have checked before opening another thread, there are already a hanful of them open, all on the same topic.
2020-4-28
Visual Air
Flight distance : 2710115 ft
The props are too flimsy. Assuming this was for weight savings but they are super flimsy. Does anyone not find it a coincidence that everyone is reporting the rear left props? Even more shocking that once replaced the error goes away.
2020-4-28
DJI Thor
Flight distance : 13602 ft
Hi, this is a new notification added to the new firmware. Please check the propellers and see if any of them have damaged or get severely bent, if so, please change the propellers.
If the propellers got slightly bent because of improper storage, please try to smooth the propellers and test again.
If the error persists or appears frequently, it is suggested to send in the drone for diagnosis.
2020-4-28
Francoisd
Flight distance : 66352 ft
Hi,
There is another thread speaking about this issue (very long thread actually), and in which, a lot of users have the same issue.
A lot of them upgraded their firmware again using dji assistant and the problem disappeared.
Those who still have the issue after changed their propeller and again, problem solved.
Try this and tell us ;)
2020-4-28
