M600 Pro bricked ! How to download older version of Assistant 2 ?
4483 15 2020-5-23
Anthony B.
Flight distance : 13832480 ft
Hello,
As I was doing an upgrade of the flight controller of my M600 Pro (A3 Pro), something failed and the upgrade stopped at 75%.
I'm using the very last Assistant 2 for Matrice (v2.0.11) available here https://www.dji.com/fr/downloads/softwares/assistant-dji-2-for-matrice
Here is what the last assistant tells me when I plug the M600 Pro
I then only have access to upgrade panel, no other tab can be used :
But upgrade fail even to start
Any idea how to reset the A3 ? or maybe access to older Assitant for matrice ?
Thanks for any help
2020-5-23
djiuser_4lMWikkc4Iys
I am having the exact same problem! Essentially the exact same things happened to me as well. Initial firmware upgrade failed around 60%-70%. I disconnected, and restarted the drone. When I powered it back on my computer actually didn't even recognize the M600 anymore and only showed me an option for Lightbridge 2. After I removed all the batteries and waited for a bit it was able to at least recognize the drone but when I tried to do the firmware update it never progressed and gave me the exact same error message. Can't even connect the controller to it anymore and am dead in the water.
2020-6-12
Anthony B.
I solved my problem using the older version V2.0.8 of DJI assistant recommanded on m600 pro specs page. The last version 2.0.11 can’t connect with the “bricked” m600
Hope it helps you
2020-6-12
Anthony B. Posted at 6-12 10:55
Hope it helps you
The only version of DJI Assistant I'm seeing on the m600pro page takes me to the v 2.0.11 page. Is there a legacy download link somewhere that I'm missing?
Thanks
2020-6-12
Anthony B.
Try that link https://www.dji.com/fr/mobile/downloads/products/matrice600-pro
2020-6-12
Anthony B. Posted at 6-12 13:05
You are a hero, that worked perfectly. Thanks!
I've worked with two different DJI drones for my jobs now and the software is just... trash honestly. Hardware is super nice though.
2020-6-12
Anthony B.
Glad I could helped. I struggled myself a full weekend ! Good at least it saved someone else
2020-6-13
inspectorherb
Hey could anybody help a poor fellow find V2.0.8 of DJI assistant, been searching all over and no dice and the above link only has 2.0.11 now.
2020-7-24
inFocus India
India
Even I had a bad experience with the new version of DJI Assistant 2 v.2.0.12 and old links were dead... Luckily v 2.0.8 was saved on my PC from before...here you go... https://mega.nz/file/4p8UBSBJ#ghI8RiuU8P89rix_F-eAiQeY5EFNZcVWhnG8c7vG6CU
2020-8-1
fans677db80f
Anthony B. Posted at 6-13 00:17
Hey bud I’m having same issue. Just picked up a m600 from a guy and it flew well. I downloaded assistant for m600 and update failed now it tells me I have wrong firmware. Do you have the older version of the assistant?
2020-8-6
Keitel Small
Hope it helps you
I’m having same issue. I did go to your link and couldn’t get that version. Would you be willing to help me out.
2020-8-6
Keitel Small
inFocus India Posted at 8-1 07:11
Hey bud having same issue. Is there anyway you can send me that older version please.
2020-8-6
Keitel Small
Same issue here man. Would you be kind enough to share that older version with me please.
2020-8-6
inFocus India
India
Keitel Small Posted at 8-6 15:56
Dji wont let post the link ... you have to manually copy and paste the given url in browser ..
2020-8-13
hovgaardradiationsolutions.ca
djiuser_4lMWikkc4Iys Posted at 6-12 10:51
Had sane problem.
Dowload ver 1.2.5.
2020-8-16
Anthony B.
Anyone tested the last 2.0.12 update ?
Mu M600 Pro is asking for a new FW but I'm quite scared to do it after the last issues ....
2020-8-26
