Rear LED change post DJI repair ?
763 4 2015-6-16
applekiller
Flight distance : 138458 ft
Hi All,
I've noticed since getting my P2 V+ V3 back from repairs that the rear LED are behaving different than I remember...  For example now during compass calibration rear left (if you are standing behind bird) led is solid amber (expected) but rear right is solid green ( I swear previously it would also be amber.        I'm in NAZA M and running 3.14.      Please let me know if I have an issue , or my memory is bad or this is a 3.14 change or result of repair ????     Everything acting and flying normally.
Thanks
Kris
2015-6-16
roy
When calibration is required you get Amber flashing. After the calibration it flashed green then goes out indicating that  that the calibration was good. If the calibration fails the. It's yellow green then flash red yellow red yellow and continues. The fail red yellow.Itmismodd one is one color and the other another. Not sure if an upgraded ESC might do that.
2015-6-16
applekiller
Hi Roy,
I have the no label esc's and had asked that they be updated to the 2.1 version ... I'm wonder if that has something to do with it...   Can some with 2.1 esc,'s confirm if both or only rear left go amber on compass calibration??
2015-6-16
JATO
I have 2.1 ESC both LEDs show the same color.
2015-6-16
applekiller
Hi Jato,
Thanks for your reply....  You running 3.14 too ?    I remember both going amber previously too...  Mmmmh
Kris
2015-6-16
