When will Multilink be fixed?
1825 6 2020-6-2
Coyut
Flight distance : 2559222 ft
Switzerland
Multilink never worked as it should.
We had so many connection losses that we have put them on a shelf a long time ago.
Cendence Master / Cendence Slave (and 2x UB CS)  work much better and more stable without Multilinks added.
It can't be that there never was a fix since the relase a long time ago.
2020-6-2
Coyut
Switzerland
Since there is no reply I guess we can finally trash the Multilinks, as there was no fix since its initial release..
2020-6-20
PH3KS
Flight distance : 39537 ft
We also ditched the Multilinks. @DJI When will this be fixed?
EDIT;
From my understanding, the Slave remote connects to Master and Aircraft.
Slave without Multilink;
Good connection to Aircraft
Bad connection to Master
Slave with Multilink;
Bad connection to Aircraft
Good connection to Master
2020-7-14
Coyut
Switzerland
We experience lots of go4 crashes and connection losses with Multilink attached.
Excactly what it was promissed to solve compared to the stock setup.
Right now the stock setup still runs better and much more stable then using multilinks.
2020-7-21
Coyut
Switzerland
No answer from dji indicates we can trash these devices finally.
I really wonder why they still sell non functioning devices...
2020-8-23
Matthew Dobrski
Flight distance : 1831050 ft
Coyut Posted at 8-23 22:34
If you don't know, who else would ?
2020-8-24
Coyut
Switzerland
DJI still ignors this problem and sells the faulty hardware in their shop...
Come on DJI you had more then 2 years now. Fix it so we can use what you promised in your shop.
2020-11-24
