Remaining flight time no longer visible
1101 9 2020-6-6
djiuser_WWvcFh7mXvCK
Flight distance : 1601194 ft
Hi fellow drone flyers,
My mavic 2 pro used to show the remaining flight time in the dji go4app. The one that is a horizontal green line with on the end the remaining time. So now since couple of weeks there seems to be a white dot over the Remaining flight time. Seems like a software issue Cause under the dot, you can still see the last digit counting down. However I did not had any update..
Anyone with the same problem or someone who can advice me?
Kind regards,
Michiel
2020-6-6
Woe
Flight distance : 4129268 ft
If you using IOS try turning off dark mode.
2020-6-6
Michiel Starfighter
Woe Posted at 6-6 22:19
Thank you Woe, I will try this later and let you know
2020-6-7
Michiel Starfighter
Michiel Starfighter Posted at 6-7 02:23
Dear Woe,
Tnx! It worked
2020-6-7
Woe
You're welcome.
2020-6-7
DJI Stephen
Hello there Michiel. Thank you for reaching out and for the inquiry. It is great to know that after following Woe post on #2 and after turning off the dark mode the issue has been fixed. If you have any other concerns with DJI. Please feel free to post it here at DJI Forum. Thank you and fly safe always.
2020-6-14
gominolo
Flight distance : 396135 ft
Hi! I have the same problem but I don't understand what is "Dark mode".
EDIT: Dark mode in my iPhone?
DJIGO4 iOS
DJIGO4 iOS
2020-6-20
kykmavic
Flight distance : 5892388 ft
Cyprus
gominolo Posted at 6-20 11:33
Yes, this is on your iPhone.
2020-6-20
gominolo
kykmavic Posted at 6-20 12:34
Great, thank you!
2020-6-20
HugoDronePilot
DJI Stephen Posted at 2020-6-14 21:29
Hi! Is there any software upgrade in progress to fix this to prevent having to switch from dark mode ?
Thank you!
2021-1-30
