Dr. Yuan Shenghai
Singapore
reference keyword. Can not create file on SSD. Write file error
By default manifold 2G external SSD does not allow any read-write function
To use manifold 2G external you need the run the following command
assume you are running a fresh dji mf2g image
Get the UUID from the command line below.
sudo blkid | grep sd
it will show dji@manifold2:~$ sudo blkid | grep sd
/dev/sda1: UUID="5d1c3f37-a6ba-4373-a600-5a3993f03a62" TYPE="ext4" PARTUUID="2fb26a0a-01"
dji@manifold2:~$
It will have in my case it is /dev/sda1 UUID="XXXXXXXXXXXXXXXXXXX"
mkdir /home/dji/storage
sudo gedit /etc/fstab
Inside in my case, it is empty. only has a default 0 1
below this default add a new line
UUID=XXXXXXXXXXXXX /home/dji/storage ext4 defaults 0 0
where the xxxxx is the file you get from UUID without the " ". close the file. restart.
Then enter the following command
dji@manifold2:~$ sudo umount -f /home/dji/storage
dji@manifold2:~$ sudo mount -a
dji@manifold2:~$ sudo chown $USERUSER /home/dji/storage
follow the image below I don't know got to get rid of this dji forum macro bug.
then the ssd is ready to use
