aburkefl
Flight distance : 78612 ft
I have a home-brew one I made from a styrofoam board. It's absolutely, totally all white - and it doesn't matter. If the sun hits that white in any angle coming your way, it's bright. If you cover the thing with reflective foil, same thing - *any* reflected angle is going to be really bright.
In monkeying with home-brew shade screens I came to the following conclusions:
(1) if it's really big enough to block the sun, it's probably too big to put in the holder and still hold something really big - like a big tablet
(2) if it's really going to be deep enough to be really dark in there, see rule #1
(3) if you want it to get really dark, throw a dark cloth over your head *and* the controller *and* the tablet, etc.
(4) if you're in sunny central Florida (or equivalent) forget rule #3 - if it's already 97-degrees F out, you don't want to cover yourself up in anything!
(5) if you fly any reasonable distance from your Home Point, Murphy's Law will apply, i.e., the direction of your bird and the orientation of your antennas will always be such that the sun will shine directly into your shade box! LOL
(6) the perfect solution may never be found, but I'm still looking too!!!
