Sean-newbie
Flight distance : 15997 ft
The assistant for the mini is this one https://www.dji.com/uk/downloads ... ant-dji-2-for-mavic
Once the assistant is running on your computer, switch on the mini and be prepared to connect it to the computer (windows) quickly, you have 20 seconds, I think, from switching the Mini on to connect it, otherwise you have to switch the mini off and on again etc. etc..
Re "For example: Last drone written image is DJI_550. Copy DJI_550 to DJI_551 and DJI_0999. Then take a picture with MM"
In the attached, I just copied any old photo, taken by the mini, back onto the mSD card ( the card was in a reader) and then renamed that old photo to "DJI_0999.JPG" ( you probably MUST keep the exact format DJI use). I put the card back into the mini and took some photos. The drone CREATED the folder 101MEDIA and saves the new photos to that new folder starting from DJI_0001.JPG as shown
Incidentally for ME to return to my original numbering scheme all I need to do is rename the 'new' photos according to the old scheme i.e. DJI_08088.JPG to DJI_0092.JPG, delete DJI_0999.JPG (this is critical) from the folder 100MEDIA, move or copy the new photos from 101MEDIA to 100MEDIA and then delete the folder 101MDEIA. (It takes longer to type that process than do it)
