Replacing Nose Cone
3598 5 2015-6-21
Yogi123
Flight distance : 3194669 ft
Has anyone replaced/removed the nose cone?
I cracked mine, bought a repalcement, but before I started taking things apart was wondering if anyone has experience with this?
Any advice greatly appreciated.
Thanks!
2015-6-21
mountmotor
I haven't cracked it, but I did remove it to do some cleaning. It is fairly simple, there are six screws that you have to remove to take off the cone.
2015-6-21
Yogi123
mountmotor Posted at 2015-6-22 02:36
I haven't cracked it, but I did remove it to do some cleaning. It is fairly simple, there are six sc ...
Thanks for the quick reply.  The four obvious screws I found.  Do I need to remove the gimble to find the other two?
2015-6-21
lkedziora
Flight distance : 808491 ft
Poland
Yogi123 Posted at 2015-6-22 02:47
Thanks for the quick reply.  The four obvious screws I found.  Do I need to remove the gimble to f ...
Here You are:
2015-6-21
Yogi123
lkedziora@gmail Posted at 2015-6-22 03:16
Here You are: https://youtu.be/8rhl2gSM3wg
Hey Ikedziora - Thanks a bunch for the response.  Perfect.
Hope I can help you out one day.
2015-6-21
lkedziora
Poland
Yogi123 Posted at 2015-6-22 03:51
I will hold You to it.
2015-6-21
