Charging both remote control and battery
11935 12 2020-11-5
SaigoneseKD
Flight distance : 2840564 ft
Hi all,
I am just be one of the first one to pick up Mavic Mini 2.  I got the FlyMore Bundle.  They just supply only 1 USB-C cable.  How can we charge both remote control and the battery hub at the same time??
Please let me know if you know the anser   Thanks
2020-11-5
Suren
Flight distance : 13498560 ft
New Zealand
Get another cable, its cheap
2020-11-5
SaigoneseKD
Suren Posted at 11-5 20:50
Thanks that is fine, but with supplied accessories, there is no way to charge 2 at the same time ,right?
2020-11-5
DJI Stephen
Hello there SaigoneseKD. Congratulations on your new DJI Mini 2 Fly More Combo and thank you for reaching out. Upon checking the in the box accessories of the DJI Mini 2 Fly More Combo I am sorry to say that there is only one ( 1 )  Type-C Cable included. You may try using your mobile device Type-C Cable to be able to charge your DJI Mini 2 remote controller. Again, thank you for your support and keep on flying.
2020-11-5
Suren
New Zealand
SaigoneseKD Posted at 11-5 20:56
Maybe, I do not have the mini 2
2020-11-5
SublimeQuad
Flight distance : 30348 ft
Correct, there is only one USB to USB C cable included so pick up a cable and you will be set. But understand, the charger dock charges batteries one at a time so hooking the remote up is just for convenience so you don't have to be there when the last battery is charged to begin charging the remote.
2020-11-6
Mr. Mongo
Flight distance : 1348 ft
You can't.  Even with a second cable plugged into  the hub, the batteries will still charge first and then the remote.  Might as well just use a second charger like from a phone or tablet.
2020-11-8
BadBert
Flight distance : 59121 ft
to bad the charge dock works like that...
I sold my mavic pro to get the mini 2, but on that one the power supply had a cable to charge the battery (or 4 with the hub) and a usb connector to charge the remote with and it would do the batteries and remote at the same time....
would love to see the mini 2 dock act the same way!!!
2020-11-12
Alevpi
Flight distance : 43560 ft
Russia
Always threw out the chargers that came with the equipment!
Triple device for charging batteries is useless in principle,
On Aliexpress there is a similar one for 2 batteries and devices that can only charge 1 battery and have the powerbank function.
2020-11-12
DGCA3
Flight distance : 465062 ft
Not having the extra short cable to link from the batteries to the remote was a difference I noticed between the Mini 1 and Mini 2. But it's no big deal. I've got plenty of cables that will work.
2020-11-12
A J
Flight distance : 13978875 ft
Simply buy another cable
2020-11-12
djiuser_ahLfGgtKeEvT
Nigeria
My dji smart remote controller is not charging, how can I boost the battery for the remote controller
2023-12-21
DJI Wanda
djiuser_ahLfGgtKeEvT Posted at 12-21 22:58
Hello, there. May we know which remote controller you are using? Normally. you can try different chargers and cables or charge it overnight and see whether the remote controller will be charged normally.
2023-12-21
