Vision Sensor Calibration error
7579 5 2020-12-1
somtito1
Does anyone have a fix for Vision Sensor Calibration being stuck at the very end of calibration?
DJI Assistant 2 - Mavic Pro 2
Error
Error
2020-12-1
DJI Stephen
Hello there somtito1. I am sorry to know that you are having issues in calibrating the sensors of your DJI Mavic 2 Pro. Please try to calibrate the said drone using a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.) Thank you.
2020-12-2
fans467c743d
DJI Stephen Posted at 2020-12-2 22:13
I am having the same issue. Screen size and resolution are fine. Any other suggestions?
2021-7-20
jamesrpm
Flight distance : 246850 ft
I clipped a tree branch and damaged my vision sensor so I found a genuine parts supplier and replaced it but it's still saying 'Vision Sensor Calibration Error', even after downloading DJI Assistant 2 and recalibrating it.. Has anyone been able to fix this..?
2022-5-18
ivnn
Ukraine
Any way to do this calibration for Mavic 3?
Thanks
2023-3-29
lucasodria
Brazil
I had the same problem and calibrated on my computer, using 1920x1080 video setting. It worked for me.
2023-3-30
