DNG files for panorama ?
3946 9 2020-12-24
buehlerbg
Flight distance : 4511 ft
I see reference to DNG files being available to construct panoramas.  My mini 2 just produces jpegs when I shoot a pano.  Is that right or have I set something incorrectly?  I would love to get DNGs for my pano construction.  Are they just for higher end DJI drones?
Thanks
2020-12-24
videoeditman
Flight distance : 6713271 ft
Switch pictures to Jpg + Raw, that should help.
2020-12-24
buehlerbg
videoeditman Posted at 12-24 11:35
no go.  I already shoot my stills RAW.  Panos are still jpg.
2020-12-24
Matthew Dobrski
Flight distance : 1831050 ft
buehlerbg@gmail.com Posted at 12-24 13:09
Total misconception. DJI app will autogenerate panoramic stitch in JPEG format only. In fact every stitching software will deliver JPEG stitch in most cases, some more advanced may offer TIFF or Photoshop native formats. Shooting option JPEG+DNG will save RAW sequence in a separate folder for further manipulation in external computer software, if you dare to create your own stitch ...
2020-12-24
Montfrooij
Flight distance : 2560453 ft
Are you talking about the single files, or the rendered output?
2020-12-24
buehlerbg
Matthew Dobrski Posted at 12-24 14:12
Total misconception. DJI app will autogenerate panoramic stitch in JPEG format only. In fact every stitching software will deliver JPEG image in most cases, some more advanced may offer TIFF or Photoshop native formats. Shooting option JPEG+DNG will save RAW sequence in separate folder for further manipulation in external computer software, if you dare to create your own stitch ...
The DNG sequence shows up nowhere on my SD card.  What folder should it be in?
2020-12-24
Matthew Dobrski
buehlerbg@gmail.com Posted at 12-24 17:06
You must request to record panoramic sequence in RAW also. By default the app will record JPEGs only.
2020-12-25
buehlerbg
Matthew Dobrski Posted at 12-25 12:19
I finally found the setting.  Thanks.
2020-12-25
goldenorfephoto
Flight distance : 3405390 ft
buehlerbg@gmail.com Posted at 12-25 12:45
You need to be already in panorama mode before selecting raw files.
but at the moment it is pointless as there is a problem with the panorama dng files showing a discoloured part of the frame.  and they dont actually stitch into a proper panorama either in lightroom, no matter what projection mode is used ,  almost a short rectangle .  file exif must be all wrong at present in the pano mode shooting !
shoot the panorama manually (not in pano mode) and stitch the raw files   works great
2020-12-26
buehlerbg
goldenorfephoto Posted at 12-26 09:06
thanks for the info.  I hope they fix the dng problem.
2020-12-26
