jon
Vertical play seems to be normal, just the shaft sliding up and down in the ball races (there are shim washers behind the retaining circlip on the bottom of the main shaft that 'should' minimise this free play, but I guess production tolerences mean some get better shimmed than others), but if you can rock it (by grasping propeller tips and lifting one, dipping the other) then not so good. I replaced the bearings in one motor because I could rock it and hear it clicking as I did so.
JMHO
Jon |
