Smart Controller + MA2 dramatically dropped the range.
3525 10 2021-2-28
vitaly258
Flight distance : 1311375 ft
Hi Guys,
I haven't fly for quite long time and yesterday went to Jurassic Coast in Devon to take some videos.
I was unpleasantly surprised that in the distance of 500 meters from start SC showed me "Weak signal. Adjust antennas". After 600-650 meters the SC had lost control completely. MA2 has a direct radio connection with Smart Controller over the sea and has no obstacles.
It seems very weird so today I've tried to test it again in the different place. It was fields with some trees but result was absolutely the same - in 560 meters from my point I had a week signal from Smart Controller and after 600 meters I completely lost MA2.
Then I've just changed Smart Controller for stock one and stock controller has flown 2,500 meters in the same direction without any problem.
I've tried this experiment again with SC firmware degraded to V1.00.0860 but without any result - Smart Controller flies 600 meters max while stock controller flies 5 times longer without any problem in the same area.
Any ideas?
Mavic Air 2
fw: V01.01.0610
Stock Controller
fw: V02.00.1200
iPhone 12 Pro iOS 14.4, DJI Fly 1.2.5 (425)
Smart Controller
fw: V1.00.0880
DJI Fly 1.2.4
2021-2-28
OlliM1971
Flight distance : 309199 ft
I have exactly the same problem with the SC, but also no solution.
I’m using the SC with a Mavic 2 Pro (and the Go 4 app). All running the latest firmware...
2021-3-1
jmb63
Flight distance : 7009439 ft
How do you have the antenna on the Smart Controller pointed?
2021-3-1
vitaly258
jmb63 Posted at 3-1 04:11
proper way
2021-3-1
Sn4pper
Does the DJI Go4 App on the Smart Control also crash?
I am having a similar issue where the App Crashes and the Drone Returns to home point.
2021-3-1
E2UNTAE
Flight distance : 607612 ft
South Korea
We are having the same problem. We are having problems after the Mavic Air 2 December update, and we are curious when DJI will solve this problem.
2021-3-1
OlliM1971
Sn4pper Posted at 3-1 09:33
The Go 4 isn’t crashing on my SC. In the meantime I also updated to the latest version from the DJI download portal - also without issues. However, I had to reset the SC after the latest update, before it was working stable...
2021-3-1
E2UNTAE
South Korea
I've been looking forward to updating to DJI FLY App 1.3.0, but it's the same.. The smart controller is really useless..
2021-3-2
djiuser_0Vnd4xeIXNp7
Posting here to try and get some help.  I will create a new thread as well as soon as DJI lets me.  I'm very very irritated with them at the moment.
Just bought the Air2 fly more with sc.  Updated everything as soon as I unboxed it (I'm an AIX/Cisco admin, consider me well versed in updates).  In the past week of flying, I lose signal around the 500M mark on totally flat ground with nothing in between.  I'm in AZ and trying things on a completely flat desert.  Got the antennas pointed at the drone, so that shouldn't be the problem.
My bigger issue, however, is that I've had the Fly app crash on me 8 or 9 times so far in maybe 4 hours of flying.  I'm not enthused about this ratio.  I pulled down the 1.3 app, even though it says it isn't compatible, and I'm going to try it tomorrow.
Now that I'm reading more through the forums looking for solutions, it sounds like DJI has almost abandoned the SC.  Lots of people with lots of problems that don't get fixed in a timely manner, considering how much this thing cost.  I'm still in my return window, so if I don't get something from them, I'll be returning it.  That was mostly for DJI to read, not for the general population.
Plus, what gives with posting?  Trying to create a new thread and it won't let me, even after verifying.  That's total BS in a support forum on a $1500 purchase.
Thanks, Larry
2021-3-5
Visual Air
Flight distance : 2710115 ft
Having the same range issue with the smart controller. I had incredible range with the factory MA2 controller but using the SC its terrible. I also live out in the country with very little interference.
Come on DJI fix this.
2021-3-6
Dr.Lars
Tried the 1.3.0 app on the SC, after I emailed DJI support and 'Jack' said to do so.  Of course, 'Jack' didn't understand what I meant by 'bought an Air 2 with FM and SC'.  He actually asked what I meant by SC, so I don't have the warm fuzzies.
However, I did try it.  It does seem to work fine and does feel smoother somehow.  I only flew for about 25 min, didn't have a problem.  Over the next few days I'll be putting some serious time on it.
Larry
2021-3-7
