Aiolos Vega
Flight distance : 7680 ft
Greece
Finally i found a rather unorthodox solution, which worked.
I remembered that there is a application in play store: Mavic Air 2 and 2S Leds Control, which turns on/turns off the leds in the drone.
I've installed it, turned the leds off and then on again and the problem was solved.
Obviously it wasn't a hardware problem but a hindrance in the drone's software.
I don't know if this was the proper way to fix it, but because i couldn't think of anything else, i thought to try this out before i send it for service.
So far so good. I've made 2 to 3 times restart. |
