Hi everybody,
I think I have do everything to install properly DJI Assistant (FPV) and attached Horndis driver on my mac (Big Sur). No success all the time...
What I have tested:
1. Installing HoRNDIS driver eg. versions 7, 8, up to 9.2 (highest driver version 9.2 still is not supported for BigSur as Author claims)
2. Installing almost all other DJI Assistants (including Enterprise version as DJI Support sugessted)
3. Trying to disable all mac secutity protections (including disabling SIP - mac system integrity protection!)
In the result I still cannot download logs and do firmware updates (althought Asisstant sees goggles and drone and can read eg. firmware version but do not see logs - even do not shows them). Of course, MS Windows 10 installed as a VM works perfect (on the same mac!).
I have two macs and the result is identical on both. (sic!)
I see that others works on mac. How (Big Sur) while driver is not supported?
Thanks for any advice in advance!
stah
ps.
Log:
Last login: Fri May 21 07:00:29 on console /Applications/DJI\ Assistant\ 2\ \(DJI\ FPV\ series\).app/Contents/Resources/installdriver.sh ; exit; stah@MacMini ~ % /Applications/DJI\ Assistant\ 2\ \(DJI\ FPV\ series\).app/Contents/Resources/installdriver.sh ; exit; Password: Executing: /usr/bin/kmutil install --volume-root /Library/Extensions/HoRNDIS.kext --check-rebuild /Library/Extensions/HoRNDIS.kext is not a volume root, skipping rebuild kmutil done
