Mini 1 to mini2.
2284 13 2021-5-24
Donut Michigan
Flight distance : 42415 ft
My Mini one is gone but not by my choice, left on roof of car and drove away |££_^]{<\~|?
But I am so happy with mini 2.The controller is so much more comfortable and having the screene in front of the controller is so much easier.
I love the controls and the things you can do with it.
Hardly have to touch the screen.
One long click with the FN button the it switches from map to forward camera.
Two clicks and gimble goes 90* down. Do it again It goes 90* back up to horizontal straight forward.
You still have the normal roll wheel.
Boy dose it fly fast in sport.
I believe much quieter. Props are stiffer.
The arms are much stronger.
But hold down on the FN button and it zooms in or out by rotating the roller wheel.
Speed switch on the controller is so nice.
Now I can fly with the leaves blowing in my treese  , use common sence.
On button switch from Camera to video.
Ocqu sink mich better.
I would have never known this if I wouldn't have accidentally left my mini 1 on the roof of my car.
I now have three extra batteries for spairs from the mini 1. So that worked out.
I guess you can see inreally like my mini 2.
I really like my Mini 2
Doug
2021-5-24
DAFlys
The mini2 and mini 1 use different batteries.  the Mini1 batteries will not give you as much power.
2021-5-24
Donut Michigan
DAFlys Posted at 5-24 23:26
I agree but I have see ranger test which I don’t do  and the performance is close and having three extra batteries is a nice backup while I’m waiting for the OEM’s.  To charge. There free and would save me a lot of money not buying any more., so I have 3+3 batteries. That’s a long time.
Doug
2021-5-24
DAFlys
Donut Michigan Posted at 5-24 23:31
Doug
Theres been quite a few threads here here people were flying with the mini1 battery and lost the drone as it didn't have the power to combat the conditions.   Also they weigh more than the mini2 battery so may affect you if you taking advantage of the 250g limit.
2021-5-24
Donut Michigan
DAFlys Posted at 5-24 23:35
I do understand that there is a great reduction in speed and wind capability’s  with the heavier batteries.
I have my registration number from FAA so I can go over 250 grams.
Most crashes are pilot error.
2021-5-24
DJI Stephen
Hello there Doug. Good day and thank you for sharing these information with us. In addition to this post I will post a link where in you can compare both the DJI Mavic Mini to the DJI Mini 2 and to other DJI consumer drones as well ( https://www.dji.com/products/com ... ndsite&from=nav ). Have a safe and a happy flying always.
2021-5-25
Tuxtard
Flight distance : 9975610 ft
Serbia
I'm a pincher, so for me it's harder to hold RC-N1 controller. Especially on the left side where I have to stretch between my index and middle finger to reach the wheel behind the phone.
2021-5-25
Tuxtard
Serbia
There is a thread for this issue here:
https://forum.dji.com/forum.php?mod=viewthread&tid=238460
But I got no definitive answer.
2021-5-25
DowntownRDB
Flight distance : 1722 ft
Sorry about losing your Mini 1.  Congrats on getting the Mini 2.  I can see you already like it a lot.  Have fun and keep on flying safely.
2021-5-25
DAFlys
Tuxtard Posted at 5-25 03:28
I wouldnt trust that opinion.   Mini 1 battery is lower voltage, lower peak current and heavier,  it won’t be able to supply as much power to the motors as the correct battery. It’s just the same as using a lower power battery in a torch, the light won’t be as bright as the proper spec battery.
2021-5-25
K6CCC
Flight distance : 651683 ft
Oops!  That would be annoying!
Glad you're enjoying the Mini 2.
I can see it now - Honest Honey, I have to buy a new drone because my Mini disappeared...
2021-5-25
Donut Michigan
K6CCC Posted at 5-25 12:53
I was planning on getting the mini 2 and keeping the mini 1 for more dangerous situations.
So now I might just keep an eye out for a cheap mini 1.
You can bet I’ll never leave a drone on my car again. Lo
2021-5-25
The Saint
Flight distance : 5902228 ft
when i first started this drone thing, i realized i was hauling a lot of equipment into and out in the field.  it become impossible to know if i left something behind especially when you make several trips and fly several drones at a time.  however, when i stand in and around my car while flying, i've made it a habit to do this each and every time without fail (regardless of the weather):  after you believe you have loaded and packed everything away and started the car, get out and do one last walk around the entire car, 360 degrees.  because inevitably you will forget and leave something on the trunk or on the roof and it will fly off somewhere along the way and you may not find it.  worse, it falls under the tire and you destroy it.   drive off and leave a tripod with a camera or monitor atop.  i have front and rear car cameras so the last time i did this, i got home and reviewed the footage and i could see where i lost it and i went back and recovered my equipment but it was scratched and damaged and i said never again.  do a walkaround.
2021-5-25
Donut Michigan
The Saint Posted at 5-25 19:39
I agree. I did change your procedure.  Also on my hood right in front of me.
2021-5-25
