Air 2S incorrectly overwriting new files on sd card. Please fix
780 10 2021-9-16
fans589cba4b
Flight distance : 12780633 ft
Dear DJI Support.
The Air 2S is somehow allowing the old files to overwrite the new files rather then the new files to overwrite old files. I was filming yesterday without having formatted the sd card and many of the new videos I shot were replaced with the old videos I shot previously with the same file number. The drone should have new files overwrite the old files but Ideally it should recognize the last video or photo file number and start the naming from there rather than alwayus starting back at DJI_0001. If people are in travel switching cards back and fourth there will be a lot of missing files when they review them. Please fix this.
Thanks
Felix
2021-9-16
Labroides
Flight distance : 9991457 ft
What you are saying makes no sense.
Old files left on the SD card can't "overwrite" new files.
If you've left files on the SD card, any new files should appear after them with file numbers following on from the older numbers.
Try a little desktop test shooting to work out what's really happening.
2021-9-16
fans589cba4b
Labroides Posted at 9-16 17:25
So your saying the new files are overwriting the old files but that should also not be happening. the drone should read the last sequence and start recording from there and not starting overwriting. I'll go out and try to replicate again and will post results.
2021-9-16
Geebax
fans589cba4b Posted at 9-16 17:33
You don't have to go out and do anything, Just test it indoors on your bench, the effects should be the same.
2021-9-16
fans589cba4b
Geebax Posted at 9-16 18:55
i'm testing now and it seems fine. I'll keep an eye out of this happens again. I'm not sure what caused it but half the new files I shot were missing. I also shot a 360 panorama and it was completely not even written on the card.
2021-9-16
Labroides
I didn't say anything like that.
2021-9-16
Geebax
You won't get much help here if you set the posts to 'Private'. Besides, old files cannot overwrite new files, unless you have managed to invent time travel.
2021-9-16
Labroides
Why did you do that?
Now no-one can see the thread.
2021-9-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. I will take note of this one and will forward it to our designated team for attention. Just a friendly reminder to back up all the files on your SD card and check the storage location every before the flight to avoid any issues. Thank you for your valued support.
2021-9-17
AlexanderK
Flight distance : 2066709 ft
fans589cba4b Posted at 9-16 19:24
This is a weird thing with 360 pano files. What happens is:
- You have all settings correct (so also save to sd card)
- Start pano
- It takes pictures to lets say 50%
- 50% to 100% in the process is the processing and saving the files
- But you used the controls before the process finished to 100%
If you use any of the controls it will not save the files to the SD card.
It took me ages to figure this out until I saw a post here that explained it.
So try again and if you make a 360 pano and save to the sd card (raw or jpg) wait to finish the process before touching any of the controls
2021-9-17
videoeditman
Flight distance : 6713271 ft
AlexanderK Posted at 9-17 23:59
- Start pano
Alex, thanks for this explanation as this has previously happened to me and I didn't know why the file stopped writing!
2021-9-27
