mixmaven
Flight distance : 1699081 ft
I would recommend that you never fly with a battery that has not been fully charged before flight or after a firmware update. The discharge recommendation is from a full 100% battery down to 5% (or 3.3v per cell), not from a partially charged battery to empty.
To answer your question, if you believe it is an esc issue, were all blades spinning on the ground? Due to your battery charge, you may have just experienced a low battery that was unable to keep the I1 in the air. I would fully charge and then discharge your batteries again. |
