P3 Advanced - not in 2.7k?
Darkpaw
Flight distance : 536896 ft
Hello.  I recently acquired a Phantom 3 Advanced.  The specs show this as being 2.7k capable.  But the DJI Go app only seems to have the single resolution and frame rate at 1080p/30.  The settings menu doesn't appear to have any option to change it.  The DJI Go app is the most recent/updated for the iPhone.
The firmware on the drone is the most current (P3A-v1.11.002).
What am I doing wrong?
2021-11-5
JetSam
Flight distance : 3462946 ft
Make sure you are using a compatible SD cARD Class 10 ...
2021-11-5
JetSam
https://www.dji.com/es/phantom-3-adv/info?redirect_info=true#camera
2021-11-5
Darkpaw
JetSam Posted at 11-5 10:25
[view_image]https://www.dji.com/es/phantom-3-adv/info?redirect_info=true#camera
So how do I get it to change modes?  There doesn't seem to be any way to do so in the DJI Go app.
My SD card is a SanDisk Extreme 64, U3/V30, designed for 4k video.
2021-11-5
Labroides
Flight distance : 9991457 ft
Darkpaw Posted at 11-5 11:31
Click 1 first
Then click 2
2021-11-5
Darkpaw
Labroides Posted at 11-5 14:03
Click 1 first
Then click 2
Unfortunately, that doesn't seem to exist on my iPhone app.
2021-11-5
Labroides
Darkpaw Posted at 11-5 15:14
That looks like the DJI Go app has been changed to look more like DJI Go4 since I last used it years ago.
In the central screenshot you posted, have you clicked either of the other two icons o the top of the screen?
That's the camera icon and the cog
2021-11-5
Darkpaw
Labroides Posted at 11-5 21:01
Yeah, the camera one is camera settings only.  The cog is for "general" settings, but has no options for resolution there.  The only spot that allows settings for video is the one that's in that screen shot, and nothing scrolls below that point (basically, what you see there is the only options available).
That seems wrong, because even if it had the firmware that didn't yet have the 2.7k enabled on it, you should still be able to select a different frame rate for 1080p.  Something seems wrong with the app.  Or I'm missing something that should be really obvious.
2021-11-6
Darkpaw
Darkpaw Posted at 11-6 16:05
Any other thoughts on this?
Surely somebody from DJI seeing this thread would know what's going on.
2021-11-8
Darkpaw
AHA!  Mystery solved.
So it is indeed under "Video size", but that button isn't under the video menu.  For whatever reason, it's under the photo menu.
And indeed, 2.7k works perfectly.  Thanks for the help.
2021-11-8
Labroides
Darkpaw Posted at 11-8 06:51
No-one from DJI, with any technical knowledge monitors the forum.
2021-11-8
