Facebook live issue - Log in disabled
2615 2 2021-12-23
Reigo
Flight distance : 1672146 ft
Estonia
Hi.
Can anyone help to solve this issue?
When trying to use Facebook live stream feature, the Smart Controller gives a following error message:
Log in Disabled
For Your account security, logging into Facebook from an embedded browser is disabled. You may be able to continue by updating the app you´re logging in from and trying again.
I´m using the latest firmware at this date (V01.01.0064) and have tried to renew the firmware with DJI Assistant 2 over USB for several times - with no success. The error message still persists.
Is there any known fix for this issue?
2021-12-23
Mobilehomer
Flight distance : 18150351 ft
It's not the firmware, it's the browser. Try installing Chrome browser.
2021-12-23
Reigo
Estonia
Mobilehomer Posted at 12-23 15:44
Actually it´s all about the firmware.
Browser has nothing to do with this issue.
I do not need to browse Facebook from my Smart Controller, I need to stream live feed to FB by using the built-in menu commands, which DJI Go 4 has.
It would be absurd to launch some other app while mid air, for streaming function anyways.
So - there must be some firmware-specific solution to this issue.
Maybe downgrading would help, but DJI Assistant 2 does not give option for downgrading the firmware. Factory reset also does not actually perform a factory reset, it only deletes some files from Smart controller, it does not restore the firmware to earlier version, which the SC had originally installed.
2021-12-24
