P4P deactivate broken left rear sensor?
855 2 2022-1-23
Yamie
Flight distance : 285551 ft
Hello,
my P4P has a broken sensor to the rear, the cable was pinched and is now broken.
A replacement is on it's way but it will take some time.
I don't realy need the back sensors, or the front and side sensors. There is the option to deactivate them, but the software stil complains that the sensor is brocken.
Is there a way to turn this check off, so that the P4P would be useable until the repair?
Thanks and best regard
2022-1-23
DJI Stephen
Hello there Yamie. I am sorry to read and to know about your DJI Phantom 4 Pro and thank you for reaching out. Since the said DJI Drone has a broken rear sensor.  It would be best to contact our DJI support team at https://www.dji.com/support for further assistance with regards to this matter. We will do there best to help and give out the best resolution for this issue. Just a friendly reminder that  DJI do not recommend doing a DIY in fixing the said DJI drone to avoid further damaging the said unit. Thank you.
2022-1-23
Yamie
Hi Stephen,
thanks for your reply.
I will try to talk to the support later
2022-1-23
