Flying at -15°C
1294 6 2022-1-29
nish_maha
Flight distance : 139298 ft
Hi,
I recently got a DJI MINI 2, I live in Winnipeg, manitoba, Canada, where the Temperature is consistently -15°C and below in winter,
can i fly my drone here?
I read the operational condition is 0°C to 40°C,
Please let me know.
2022-1-29
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2022-1-30
DJI Stephen
Hello there nish_maha. Good day and thank you for reaching out. You are correct the DJI Mini 2 has an Operating Temperature of 0° to 40°C ( 32° to 104°F ). Kindly please fly your DJI drone following the recommended flight environment and temperature to avoid any unwanted incident that might cause damage to the said DJI drone and might void its warranty as well. Thank you and fly safe always.
2022-1-30
Blériot53
Flight distance : 6260935 ft
Have a look at this - it may help you decide
2022-2-7
-Lucifer-
Flight distance : 1307795 ft
I do fly the mini 2 and air 2s even in -20c  If it’s colder the gimbal usually freezing up. Filming a lot in a Yukon. Only issue it’s a shorter flight time..
2022-3-17
djiuser_SG95p3Obv4vx
-Lucifer- Posted at 3-17 06:54
Hi, I live in Edmonton which shares winters close to those of Winnipeg.
I've taken my Air 2s out when the temps were -10 C without problems.
The drone and batteries are usually kept in a warm car and once flying the batteries do generate a fair bit of heat.
So, not sure abut -15 C but -10 C for me is fine.
2022-3-27
-Lucifer-
djiuser_SG95p3Obv4vx Posted at 3-27 12:13
Edmonton almost -20C
2022-7-12
