Video Flicker (Serious Issue)
1821 10 2022-2-10
ianwood
Flight distance : 5236 ft
There should be no change in exposure at all which is confirmed in the SRT file (see settings below). If you can't see it, look at the sky. It's more obvious when I scrub through the video. Easier still, look at the scopes on the left side and it will become even more evident.
ProRes 422HQ, 5.1K, 50fps, manual exposure
[iso: 100] [shutter: 1/50.0] [fnum: 5.0] [ev: -0.3] [ct: 5600] [color_md : default] [focal_len: 24.00]
I need to go back and see if this was in any of my footage from the previous firmware versions.
2022-2-10
ianwood
More examples. Occurred twice in one 25 minute flight. Each time it was a single frame that changed exposure in the mid-tones and highlights.
Surprised no one else is picking up on this. Then again, if you're not a pixel peeper, it is easily missed. Easiest way to spot it is with the luma scope which I use extensively to grade footage.
I highly doubt this is result of a defective unit. This would be a very unusual mode of failure.
2022-2-17
Geebax
You can lock down all the factors affecting exposure, and the camera will still try to auto-expose the image. I don't know why this is so, but it has been happening for quite some time in the Mavic series aircraft. Back in the days of the Phantom series, you could lock them down and they would stay that way.
If you watch the white house on the left of frame and the luminance scope, you will see the luminance go down as soon has it passes out of frame.
2022-2-17
Montfrooij
Flight distance : 2560453 ft
Seems they apply some kind of optimization after the image is captured.
2022-2-18
seattle_helo
Flight distance : 56533511 ft
I only record PR with the M3 and have not seen this.
2022-2-20
ianwood
seattle_helo Posted at 2-20 11:12
I've now seen this on two Mavic 3 Cine so far. It isn't common and it's not easy to spot. I've checked ten or so collections I've shot on the M3C and found two so far that had flicker (each had only a few occurrences out of 20+ mins of footage each). It can be just a single frame or a long shift. It only happens in specific situations. It seems DJI is doing some sort of image adaption on the ProRes footage even with everything set to manual.
It's as if there are different gamma curves being applied in camera based on EV or percentage of frame above 80 IRE, etc. It's almost like a built-in highlight recovery that only kicks in at certain times.
DJI, please can you explain and address this?
2022-2-21
Geebax
ianwood Posted at 2-21 17:15
The DJI technical people do not participate in this forum, the best you will get is a vacuous response from one of the moderators promising to "escalate the situation to the responsible department", meaning they do nothing.
As I said earlier, setting everything to manual has not worked for me on my aircraft, it still performs a form of automatic exposure using simple gain, disguised as ISO.
2022-2-21
ianwood
DJI needs to address this:
2022-4-8
fans9df1eb6c
Flight distance : 6975486 ft
Just found this post and following. Having similar issues with my M3Classic and M3Pro though I need to do a few more tests as it's not with all my videos (though I'm a newbie when it comes to videos).
Thanks
2023-6-16
willval
Same issue here...
2023-6-16
Golfer70
I´ve some flicker in the bottom corners & the DJI did not really lnow what so say about it:
Video >> https://youtu.be/5b_557ut5KM
It can be observed in the very first scene of the video (taken with the Air2s) or in 2:56 (taken with the Mavic 3 classic)
I remember Canon had flickering problems when the sensor got hot, might be a similar problem here?
2023-6-20
