Phantom4 multispectral camera swap
jd_nelly
Is it possible to switch out the multispectral sensor with the standard 20MP camera, in order to utilize a single platform for multiple mission types?  It seems it may be as simple as swapping the gimbal unit, but I would assume there is also a firmware change needed.  Any info on this particular matter concerning the older phantoms would also be appreciated.  Thanks.
2022-2-26
patiam
Flight distance : 32808 ft
They're certainly not designed to be swapped by the user... Not saying you couldn't but it doesn't seem to be something you'd want to do on a regular basis. Too much chance to gank something, and as you said there may be FW or other changes that must be made as well.
The Phantom platform is simply not intended for swappable payloads. Get a Matrice.
2022-4-28
fans83de767c
Norway
I do have several p4p's, and want to swap the multispectral camera on one of them with a standard camera. (Because of the rtk-module on the multispectral). Is it possible?
2023-3-9
fans83de767c
Norway
Nothing.
Good to learn what to expect from the official dji forum
2023-3-11
patiam
Lol. You know without asking what the "Official" DJI response was going to be, if they even responded at all. "Not possible. Not supported. Not recommended".
Not sure what you expected.
2023-3-20
