HUNkisvex
Flight distance : 2088219 ft
Guatemala
Hey there,
Just wanted to share with others, since I couldn't find a normal article with similar issues.
Long story short I'm traveling in Guatemala and for some reason my drone lost 2m altitude within secounds without me touching the contollers and splashed into the shallow water.
Within 10-20 secounds I jumped after the drone, got it out (the light was still on) and I removed the battery immediatelly.
Here step by step what I did, battery removed already
1 DAY
1. Freak out since I landed an other drone just a month ago in the water (my fault).
2. I found an electric pump and tried to dry it out as quick as possible from every direction ( at least for 10 minutes just to make sure). I have heared that someone dried it out with an oven on 40C so if you have an oven you can try that as well.
3. I left the drone outside with the battery next to it.
2-3 DAY
1. Already read through every articles, no chance to do service or repair it by myself.
2. No sun so basically just left at the house for drying, DIDN'T TURN IT ON.
4 DAY
1. Try to turn it on, working, do a quick hovering test, working but can't turn it off.
2. Be happy leave an other day for drying.
5 DAY
1. Turn on try to turn off, no possibilty just by removing the battery.
2. Avoid the previous line, be happy it's working go for a test round near to an opened field.
3. Connects quickly, reach 14-17 satelites, homepoint updated fly for 5 min feel comfortable, without warning within 100m it disconnect, impossible to reconnect but luckly return to the home poin.
4. Can't turn it off, one light is still on (from the 4 underneath).
6 DAY
1. Repeat the previous day, but now disconnects within secounds next to the controller and the right and left side leds are on the middle two is off.
7-12 DAYS
1. Stayed in the box and praying
13 DAY
1. Go for a test run, everything works fine, maybe it is moving a bit more while hovering but it's fine, but the camera is foggy
2. Start the dron with 30-30 minutes with 2 batteries and just hoover it in one spot.
3. Satisfied and happy.
14 DAY
Everything goes back to normal
I'm not sure if this will help anyone but I'm just so happy about this, hopefully you won't have to go through all this trouble ;)
