Firmwarer update failed ... Mini blinks red ... *SOLVED*
5358 7 2022-3-20
LeChuck71
Flight distance : 68786 ft
Hello everyone,
I have a problem. Today i switched on my Mini 2 and performed the firmware update.
The update finished at around 76% and I lost my patience after 20 Minutes and tried to switch it off.
Because the battery button did not work and the mini looked unresponsive and pulle dout the battery.
Now if I switch it on the light goes form green blinking to red blinking and stays in that state - rate is about one blink per second.
Battery indicator shows most left and right lights on with the two in the middle off - no reaction to battery button.
There is a YT video that says you should give the mini time to update - but even after 30 mInutes nothing changes form the red blinking.
App says Firmware updated downloaded and if I press update a message box pops up wtelling me its checking battery status which takes about 1 minute - nothing happens after a lot of minutes.
Using DJI Assistant only allows me to download the log - all others items are not accessible before I reboot the device ... which is not possible.
Any suggestions on how to proceed are greatly appreciated
Have a nice Sunday
2022-3-20
Johnny_J
Sweden
What happens if you try with another (charged) battery?
2022-3-20
hallmark007
Flight distance : 9827923 ft
You can factory reset or go back to earlier FW in assistant and restart the new FW. Just make sure your assistant is up to date, this SW is a crock of SH and needs patience.
2022-3-20
smbishop
Flight distance : 1859232 ft
This video might help you using DJI Assistant:
2022-3-20
LeChuck71
smbishop Posted at 3-20 06:28
https://youtu.be/F4XUVLK1KfU
Hey man, the video helped a lot - update took 5 Minutes and everything is working again.
1000x Thank you ;)
2022-3-20
smbishop
LeChuck71 Posted at 3-20 06:55
1000x Thank you ;)
Awesome, glad it worked out!!
2022-3-20
hallmark007
1000x Thank you ;)
Good news, all good now.
2022-3-20
DJI Paladin
Flight distance : 318 ft
Hi, LeChuck71. We're glad that you have already managed to isolate the issue that you experienced by the help of our fellow DJI pilot. Please don't hesitate to reach us if you have other inquiries or concerns. Thank you for your valued support.
2022-3-20
