Mini 2 issues with connection
1524 5 2022-4-24
dji TO88
Flight distance : 4678 ft
Hi, all would anyone be abe to help I just picked up a Mini 2 and tried to setup on the using DJI fly. I did the rebind and the Drone seems to bind to the radio but when I try to connect to my phone using the iPhone cable I keep getting a message "RC not connected" and the Red Led light flashes slowly can't get a connection with my iphone. Can anyone shed some light on this issue?
Thanks in advance!
Ed
2022-4-24
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm what specific iPhone are you using with the app? In addition, could you please try to uninstall and reinstall the app to see if the issue persists? Please keep us posted. Thank you.
2022-4-24
dji TO88
DJI Paladin Posted at 4-24 22:20
Thanks for the reply I'm using a iPhone XR with iOS 15.4.1 will give this a try will remove and reinstall the DJI Fly app and post results.
2022-4-25
dji TO88
Still can't figure this out removed and reinstalled the app also tried my iPad today and same issue. I tried to go to control---Connect to Aircraft I get this message "LINKING FAILED" the Drone flashes "Red"
Any suggestions? Has anyone else experance this issue? Could it be a faulty cable that connects the transmitter to the phone?
2022-4-25
dji TO88
Figured this out the USB C port is the right port the hole in the left side is nothing but a storgae hole.
2022-4-26
DJI Paladin
dji TO88 Posted at 4-25 05:40
Thank you for your response. Please keep us posted after you did the troubleshooting. Have a good one.
2022-4-28
