Is this about the same physical size as the mini 2 and will it fit in the mini 2 charging dome? It looks like the usb C connector is in about the same location.
Hi there. Thank you for reaching out. Just to verify, can you please the exact inquiry that you are referring to in the post? Are you having trouble with your charging hub? Please keep us posted. Thank you.
Wont work. Air2s battery can not be charged by USB C even if the plug did work. But, if I recall, the MINI 2 plug is straight out of the back and the Air2S is on the side!
