Questions about the mini 3 pro rc
2188 10 2022-5-27
George GR
Flight distance : 2990653 ft
Greece
Hi to all,
I have some questions and I would ask only people who own the dji mini 3 pro to answer!
1) in the rc remote control will I be able to put an app eg litchi?
2) I have seen many videos about the range test and I see that everyone has a problem with the signal! and dji says "Max Flight Distance
18 km (with Intelligent Flight Battery and measured while flying at 43.2 kph in windless conditions)
25 km (with Intelligent Flight Battery Plus [7] and measured while flying at 43.2 kph in windless conditions) "
this problem will be solved with some upgrade;
3) The screen capture is very crap 720p, this will make the resolution clearer when one captures a video screen with some upgrade;
with the dji mini 2 Full Urban Environment I reached 4600 meters! without hack and ce model!
please only answers from people who own the dji mini 3 pro!
2022-5-27
Tez4UK
Flight distance : 142349 ft
Andorra
As far as I know you can not put apps on RC.
2022-5-27
MySky
Flight distance : 364902 ft
1. Not yet.
2. Range anounced for O3 is only max. 8km CE and 12km FCC. transmission distance. (Around your RC)
    What you are talking about is the max. flight distance within the transmission distance (range).
3. Already discussed in several other threads. If did not miss something, no information from DJI yet.
2022-5-27
George GR
Greece
MySky Posted at 5-27 23:19
1. Not yet.
do you have the dji mini 3 pro?
2022-5-27
George GR
Greece
Tez4UK Posted at 5-27 22:56
Tez4UK, thanks!
2022-5-27
MySky
George GR Posted at 5-27 23:25
Mine has not arrived yet, but we have tested on the one from a friend, because we want to use litchi as well.
2022-5-27
hallmark007
Flight distance : 10017858 ft
I have a Mini3 pro.
1/ not yet and most likely no
2/there is no problem with signal, its the same as any dji drone. If you fly it in areas of high interference then this will have an affect. But the signal and video downlink are strong.
3/ screen capture is low res
2022-5-27
George GR
Greece
hallmark007 Posted at 5-27 23:50
I have a Mini3 pro.
hallmark007 thanks!!
I hope they fix these problems
however in videos with comparisons of mini 2 and mini 3 pro at the same point the mini 3 pro loses the signal!
2022-5-28
hallmark007
George GR Posted at 5-28 01:45
I have both seen and watched many videos, I have also now tested Mini 3 against Air2s and found no difference in signal or interference. In fact the level of interference and the locations are almost identical.
Check out video below from a very experienced Radio Operator. My experience is very similar to his.
2022-5-28
Bigplumbs
Flight distance : 620164 ft
I have a Mini3 pro.
Spot on and I also have a mini 3 Pro
2022-5-28
GLOBAL HAWK
Flight distance : 287841 ft
The question I have is why do you need to fly a mini or any drone to 4600m away.
2022-5-28
